Shocks
Mikey. I remember doing my set on the kettle.
The oil level is to the top when you stand the shocks in a certain position, so it runs over the reservoir. (I think it may be so the reservoir is at 45 degrees)
As for weight of oil, that is a variable like the shims in the valve. I had 10 weight hydraulic oil to hand so used that. You could use 5, 10, or even 15 weight so that gives you some scope for trial and error.
But I think the handbook said 5 weight.
phil churchett
Users browsing this forum: Google [Bot] and 44 guests
