Z1000 CLUTCH RATTLE
Z1000 CLUTCH RATTLE
NOT THAT BOTHERED
Z1000 A2, GS1000E, RD250B,C,D,E. RD400D, 1976 FIZZY, 1973 SUZI AC50 & MORE.
Usually its the shock absorber springs fitted in the back of the clutch basket....
This is quite common coz they get slack & sometimes break with use/abuse/age...
Only cure is engine split (to remove clutch) and fit good basket or repair (kits are readily available)
If its not slipping or juddering, then don't worry too much....
Z1000 CLUTCH RATTLE
Pigford wrote:Usually its the shock absorber springs fitted in the back of the clutch basket....
This is quite common coz they get slack & sometimes break with use/abuse/age...![]()
Only cure is engine split (to remove clutch) and fit good basket or repair (kits are readily available)![]()
SO I TAKE IT YOU CANT REMOVE THE BASKET WITHOUT A STRIPDOWN ?
Correct...
Only on later models.... without a kickstart....
The kickstart unit is in the way so the clutch cannot be removed...
I believe some people modified the casings so the clutch can be removed without a full stripdown, but that was for 'racers' and the like
Its not uncommon for the larger Jap bikes of the late 70's - early 80's to suffer from clutch rattle (like GS/GSX... etc).
It could even be the main bearing behind the clutch, but these rarely cause problems.
i wouldn't worry too much mate, it "character"
Your right there piggy my GS1000 suffered with this and it was the clutch basket needle roller bearing changed it once and it cured it but the rattle gradually returned and never changed it again and it went on like that with no problems for another 10 years.
Iain marshall
Re: Z1000 CLUTCH RATTLE
qwacker9 wrote:anyone know whats he quick fix ways of curing clutch basket rattle on a Z1000 A2. its fine when cold but once its fully warmed up it rattles but goes off when the clutch is pulled in. ?
cheers
I take it you've tried having the carbs balanced,just a thought as if they're out of balance it can cause clutch/trans rattles.Would try that first before stripping the clutch down.
