rubber cover
bunnysZ
Granny Magnet
rubber cover
#1 PostAuthor: bunnysZ » Fri Nov 21, 2008 4:57 pm
does anyone have or know where to get the rubber cover that goes over the oil pressure assy, goes on the top, covers the wire that goes into the starter motor box area.
also need the s bend pipe from the breather bolt into the undernath of the airbox,
both items for a z1a not sure if its different for other models.
many thanks
tlc
#2 PostAuthor: tlc » Fri Nov 21, 2008 8:59 pm
Paul. Try Bike Bandit ?
Don`t order anything until you talk to me or some others though as the postage is £40 every time you order :shock:
Hobbo
International Rep
pipe
#3 PostAuthor: Hobbo » Fri Nov 21, 2008 10:07 pm
BUNNYZ
PAUL I HAVE THE S BEND BREATHER PIPE YOU CAN HAVE PM ME YOUR ADDRESS OR CAN BRING WITH TANK TO BEERZ IN THE SMOKE
PHIL
International Rep
GUYZED
#4 PostAuthor: GUYZED » Sat Nov 22, 2008 1:19 am
Paul,
Try z power for the rubber cover that goes over the oil pressure switch.
Does your old one keep popping off :?:
Got one for my Z1000 - not genuine but i'll be hard pushed to notice the difference from standard
#449
Z1000A2 Z650B1
bunnysZ
Granny Magnet
#5 PostAuthor: bunnysZ » Sat Nov 22, 2008 8:19 am
cheers phil, bring it with you, another beer I owe you. :shock:
guy this one is off the the Z1A and its not there at all,
will give z power a call
#6 PostAuthor: chrisu » Sat Nov 22, 2008 8:23 am
looks like you're buying all the beer at this rate............. :D
Users browsing this forum: Google [Bot] and 24 guests
