Crankshaft rotor - what model?
martinz1000r
#1 PostAuthor: martinz1000r » Mon Nov 24, 2008 1:44 pm
Can anyone identify what model this rotor should fit? It has GP9325 stamped on the back and there are 6 magnets inside it.
I bought it as i was told it fitted Z1000R/Gpz1100 engines but it does not even though it looks identical in size etc. When it is torqued up it locks the starter clutch.
If I can find what it is supposed to fit I will sell it complete with starter clutch it came bolted to. It is in very good condition.
#2 PostAuthor: Pigford » Mon Nov 24, 2008 6:13 pm
My Z1000R2 (83) has GP9307 stamped on the back :??
martinz1000r
#3 PostAuthor: martinz1000r » Tue Nov 25, 2008 4:12 pm
Same as my one that fell apart and deposited bits of magnet in the sump!
london calling
#4 PostAuthor: london calling » Tue Nov 25, 2008 5:16 pm
A rotor from a Z1000 J1/J2/J3,Z1000 K1/K2 (LTD) or GPz1100 B1/B2 should do the trick.
The uni-trak ZX1100 has different internals to the earlier twin shock models.
I think pattern rotors are available new.
Jack
martinz1000r
#5 PostAuthor: martinz1000r » Tue Nov 25, 2008 5:37 pm
Jack - sorry you missed the point there. I wanted to know what the rotor in the original posting was off so I don't pass it on to someone else under false pretenses!
I managed to get a proper replacement rotor from Electrex World near Reading.
