900 Sleeve
willjanuk
900 Sleeve
#1 PostAuthor: willjanuk » Tue Dec 23, 2008 8:14 pm
Hi and a Merry Christmas to everyone out there.
I haven't posted on here for a long time, but wondered if anyone could help me out with fixing this, I have just received my cylinder head, cover and barrels for the Rickman CR900 that I am re-building back from getting them vapour blasted and the bottom of one of the sleeves has been broken in transit, (photo I hope).
They are 900 barrels that have been bored out to 70mm 1015cc, so basically I need a sleeve that I can get bored out and refit the piston.
Thanks Will.
#2 PostAuthor: Pigford » Tue Dec 23, 2008 8:18 pm
Having a new liner pressed out then refitted to your barrels will be expensive.... :evil:
Are the barrels & pistons freshly rebored or was it a used motor :?:
hillbilly
#3 PostAuthor: hillbilly » Tue Dec 23, 2008 8:30 pm
i have some spare barrels for 900, :D
willjanuk
900 Sleeve
#4 PostAuthor: willjanuk » Tue Dec 23, 2008 9:23 pm
Hi,
I have been talking to a mechanic friend of mine and he seems to think that I can use the barrels as they are, as the piece that is broken off is in the hatched area of the piston and the rings don't come down that far.Image
I hope this pic works,
Thanks Will.
willjanuk
900 Sleeves
#5 PostAuthor: willjanuk » Tue Dec 23, 2008 9:32 pm
IMG]http://i540.photobucket.com/albums/gg330/willjanuk/P1010304.jpg[/IMG]
willjanuk
Photo (at last,lol)
#6 PostAuthor: willjanuk » Tue Dec 23, 2008 9:36 pm
Steve Cooke
#7 PostAuthor: Steve Cooke » Wed Dec 24, 2008 1:17 am
They are still usable, a little extra care when fitting the pistons might be needed that's all.
PaulMceleney
Chunks
#8 PostAuthor: PaulMceleney » Wed Dec 24, 2008 2:48 am
and some super glue
#9 PostAuthor: Pigford » Wed Dec 24, 2008 11:13 am
Just file the edge real smooth.... :??
Luckily the damage is at right angles to the forces the piston will be exerting... (fore & aft) so you may well be ok.... :wink:
It could be a good racing mod.... lightening the bike :twisted:
willjanuk
Dampers
#10 PostAuthor: willjanuk » Wed Dec 24, 2008 1:11 pm
Hi,
Thanks for the replys, another little problem before I start putting it back together.
The dampers in the bottom of the barrels, how important are they, as one just drops down inside the fins and the others are below the surface.
Should I replace them, ? that will mean that I will have to wait untill after Christmas to get the bike back together, which I was hoping to get finished in the next couple of days.
Thanks Will.
#11 PostAuthor: Pigford » Wed Dec 24, 2008 1:17 pm
The rubber damper for the guide wheels are quite important :shock:
I have skimped in the past :oops: reusing old hardened rubbers... :??
This didn't cause any real problems.... BUT.... as you've got the motor apart it'd be a shame not to replace them.....
If they get really brittle & break up.... could be a problem :evil:
They also stop parts rattling :wink:
Patience is a virtue..... & pre-planning is a skill :lol:
Steve Cooke
#12 PostAuthor: Steve Cooke » Wed Dec 24, 2008 1:29 pm
Mark I think Will means the round anti vibration rubbers which go in the holes through the fins.
Will if you do mean the round rubbers I wouldn't worry about them I can't say i've ever noticed any difference with or without them, if they do make any difference it's negligible and probably only work for a short time as they harden up very quickly.
#13 PostAuthor: Rich » Wed Dec 24, 2008 1:54 pm
Just put some silicon around them to glue them in, they do better at keeping the crap out than anything else.
willjanuk
Dampers
#14 PostAuthor: willjanuk » Wed Dec 24, 2008 3:23 pm
Hi Guys,
Thats what I wanted to hear, I could'nt see that they do very much and did'nt want to wait till after Christamas.
Thanks Will.
1973 Z1 1974 Z1A
Users browsing this forum: Google [Bot] and 27 guests
