chain oil pump
Steve S
chain oil pump
#1 PostAuthor: Steve S » Thu Jan 01, 2009 2:30 pm
Does anybody run with the chain oil pump fitted but dry Ie with no oil in the tank,is there a problem with doing this(apart from the chain not getting lubed!! i know) with running the pump dry :?: :D
Also there is only one connection to the pump so how does it work :?:
Thanks Guys/Girls
hillbilly
#2 PostAuthor: hillbilly » Fri Jan 02, 2009 8:55 pm
i would tend to think running it dry would knacker it up,(you wouldnt run yur engine dry would you) :roll:
Davy Doherty
#3 PostAuthor: Davy Doherty » Sat Jan 03, 2009 8:35 am
It will shag it don't do it, but if you want to keep it on, the shaft can be removed,,
Steve S
#4 PostAuthor: Steve S » Sat Jan 03, 2009 9:53 am
Thanks guys,thats what i thought,seems the drive for the pump is provided from a pin on the output shaft locating in a slot on the pump drive shaft. The Pin has been removed from mine so i reckon i can fit it safely without fear of driving it dry. :D
Still curious as to how the pump supply,s the oil, the book says it 'splash feeds',there is only one inlet pipe connection which i presume is from the tank but cant seem to see where the oil exits :roll: am i being a little thick :roll: :?: any one know the answer :?:
z2.john
#5 PostAuthor: z2.john » Sat Jan 03, 2009 10:15 am
Quite right Steve, if the pin's out you can run it dry.
John
