Rebuild Koni shocks ?
Monk
#1 PostAuthor: Monk » Fri Jan 16, 2009 6:34 pm
Anyone know where I can get a set of Koni shocks rebuilt ?
#2 PostAuthor: Pigford » Fri Jan 16, 2009 6:39 pm
The company is now called Ikon, so have a Google....... :wink:
brian 1100
#3 PostAuthor: brian 1100 » Fri Jan 16, 2009 7:47 pm
Revs Racing will rebuild just about anything and they have a fairly quick turnaround.
But as Pigford says, they're now called Ikon and it may be cheaper to buy a new set.
Maxton do an equivalent but with an alloy body to make them lighter. About £300 though but probably excellent quality.
Brian
london calling
#4 PostAuthor: london calling » Fri Jan 16, 2009 8:46 pm
Ikon are Koni replicas aren't they :?? :?:
Jack
big green bus
#5 PostAuthor: big green bus » Fri Jan 16, 2009 9:05 pm
i can get them repaired for about £70 to 120 depending on what is needed, 120 if the rod needs replacing with a stainless steel one. the guy works for ohlins so he know his stuff
Taffus
#6 PostAuthor: Taffus » Fri Jan 16, 2009 9:16 pm
Duh!
I should asked the same question last year :oops:
Spent a lot of time trying to release the dial a ride and free up inset nut at the top of the, bought pin wrenches etc
ended up boiling the dial a rides in vinegar........that worked! dial ride freed up but never got that nut undone......
