any one have any tips on what and how to clean the inside ,
not flakey rust just very dry and dusty inside, thought it would be best to give it a clean first
Davy Doherty wrote:I recently used Brick cleaner/ Patio cleaner acid and flushed out mine,
I poured about a pint of the cleaner into it swirled it around for ten minutes and then immediately put the hose into it and flushed it out for about an hour with the tank sealed at the bottom so the water came out the filler neck,i then used a coat hanger with a chamois attached to it to dry it out and then poured some stihl two stroke oil into it and swished that around and it's like new shiny bright steel and cost me nowt to do. i'll post a pic of the inside of the tank if you want..
Rich wrote:I would have got rid of all the rust etc before having it sprayed, so I hope what BunnysZ is talking about is only overspray and dust from the spraying.
tailiftchris wrote:Rich wrote:I would have got rid of all the rust etc before having it sprayed, so I hope what BunnysZ is talking about is only overspray and dust from the spraying.
It does say overspray / dust. I would think that the solvent effect of petrol will shift it anyhow.
Mucho shaking of the tank after a week or so ought to do it ?
