oil cooler fitting
dougie
oil cooler fitting
Hi,
guys,anybody have a diagram for fitting an oil cooler to a Z1.
Thanks,dougie.
Thanks,dougie.
Dougie..... what you want....... how to fit lines... or mount cooler or what...
If its just connecting the cooler.... you need to swap the standard oil switch unit (rear of barrels under the middle carbs).... & fit a modified pair of take-offs......
Then you just run the s/s braided pipe to the cooler.....
Doesn't matter which way it flows to/from cooler, just make sure you mount it with the cooler connections facing UP
I have a complete oil cooler set up if you're after one...
