dwhitehouse wrote:Here you go then guys.Any idea what this brake master cylinder is off ?
Anyone got a spare lever they want to shift?
That is 100% Suzuki GSXR..............
tailiftchris wrote:Hey D. You ain`t too far off stock, but also you have a great bike to start modifying to your taste.
Of course you could just ride and enjoy as is![]()
Which way you gonna go
chrisu wrote:dwhitehouse wrote:Here you go then guys.Any idea what this brake master cylinder is off ?
Steve R wrote:Swapping the forks is easy, you will probably need to loosen the banjos to adjust the brake hoses and that means you will have to bleed the brakes.
Since its a new bike to oyu its probably a good idea to change the fluid any way, but be warned they can be a bitch and a half to bleed, search the site for tips. I use 2 of those little tubes with a one way valve on from Halfords, but its still a nightmare getting all the air out.![]()
If you are going to look for a standard master cylinder then be aware that there are different types for twin and sinfle discs and they look very similar but the bore size is different.
Users browsing this forum: Bing [Bot] and 54 guests
