z1000 starter
sp.milne
z1000 starter
#1 PostAuthor: sp.milne » Mon Feb 09, 2009 8:18 pm
Hi the starter motor does no seem to engage properly. Turns motor for a second then disengages or more often than not just spins without engaging. Is it the starter clutch that knackered ?
thanks stuart
#2 PostAuthor: Pigford » Mon Feb 09, 2009 8:26 pm
Think you've probably guessed right... :evil:
Easy to fix.... repair kits still available too :wink:
Its good to check rotor & starter gear coz the 3 x bolts are prone to coming loose & f88king the rotor :shock:
sp.milne
#3 PostAuthor: sp.milne » Mon Feb 09, 2009 8:33 pm
Thanks will check the bolts. think wemoto sell the repair kit.
regards Stuart
bunnysZ
Granny Magnet
#4 PostAuthor: bunnysZ » Mon Feb 09, 2009 8:57 pm
sp think I have a spare one in the garage , if you want to try that first.
Users browsing this forum: sean_rfi and 38 guests
