This is what I will be working on soon!
Padders
#16 PostAuthor: Padders » Sun Feb 22, 2009 7:36 pm
Be there with me wallet on the 7th Neil
ted1r
post
#17 PostAuthor: ted1r » Sun Feb 22, 2009 7:40 pm
Padders I think that Mick wants to come as well.
Ted.
Ps better go in his van, with our luck at the moment, well anything could happen :lol:
Padders
#18 PostAuthor: Padders » Sun Feb 22, 2009 7:43 pm
Sounds good to me
compo z1r
padders
#19 PostAuthor: compo z1r » Sun Feb 22, 2009 7:47 pm
PADDERS wrote:Sounds good to me
ted ian call on me ill' show you the way :roll: cupper's are on me :lol: :lol
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Padders
#20 PostAuthor: Padders » Sun Feb 22, 2009 7:51 pm
Your on.
Scott sorry for hi jacking your thread.
scott reid
#21 PostAuthor: scott reid » Sun Feb 22, 2009 8:19 pm
#22 PostAuthor: paul doran » Sun Feb 22, 2009 8:22 pm
good luck with this
you have your work cut out for you there
#23 PostAuthor: Pigford » Sun Feb 22, 2009 8:30 pm
Scott, this bike is gonna be even better coz of the state you've started it in :wink:
Make sure you do a comprehensive write up as you go :P
scott reid
#24 PostAuthor: scott reid » Sun Feb 22, 2009 8:39 pm
Zed1015, I'm impressed that you spotted the oil pressure gauge from that photo!
The bike had been sitting for about 7 years when I got it. Paid enough (too much), but I still thought it was ok for a '73 bike. The motor turned over and had compression so I took a gamble. Put oil and wd40 down the spark plug holes and left it.
I had to do some fault finding in the wiring before I got a spark,(lovely fat spark from the dyna coils and talor leads!
Last week I took the carbs off........F*@k me, wot a mess inside! The floats would not even move, and I couldn't see thru any of the jets.
Cleaned them out, stuck them on the bike, fresh petrol, battery, turn the motor with the kick start a load of times then switched the ignition on......
THIRD KICK it fired up! I only let it run for about 10 seconds then switched off. I am going to put some cheap oil in for the next time then dump it out after another short run.
Scott
knut
#25 PostAuthor: knut » Mon Feb 23, 2009 1:22 am
well you,re half way there already ,the fact it ran,
best of luck with the rest of the rebuild .
RoyNorway
#26 PostAuthor: RoyNorway » Mon Feb 23, 2009 10:05 am
Nice project! :P
Remember lots of pics... So we can watch the progress. :P
Z1000J 82 model, and Z1000R 83 model, And The Calfshit-GPZ1100-
