Alternator Rotor Removal - A useful tip!
A useful tip for helping with the alternator rotor removal - put a tight fitting copper washer in the bolt hole for the special tool / wheel spindle to bind against, a bit of grease on it helps the rotor come off without the tool binding on the end of the crank.
Rich, you have me beat!..... What special tool? are you talking about a bolt from the steering head that fits into the alternator rotor, magnetic core... is this a Z1 alternator? Not wishing to knock any help, we usually use a 3/8" ball into the hole and press it out by means of the bolt?
Regardz ~ Garn
Regardz ~ Garn
Perhaps Rich means special tool #57001-1099?
Kawasaki used to supply this tool with one thread size but nowadays it comes with a different size each end and a hex shape midway along the shaft to which you can fit a 17mm (?)ring spanner.
Good tip Rich, thanks
Too busy (err lazy) to learn to post a pic
Personally I use an old H**** Rs250 rear axle - 'cos I've got one in the garage. Yes Kawasaki have a special toll for it, the thread diameter changes on the mk2s to the earlier rotors. You can use a ball bearing as you say get one that fits well - you don't want to ram it up the holding bolt hole! but a copper washer will leave more threads to take the strain.
