HI EVERYONE IM NEW TO THE BOARD BUT HAVE BEEN A MEMBER OF THE CLUB FOR A WHILE... NOW THE PROBLEM.. I HAVE A MINT 900A4 IN THE RARER COLOUR BROWN AND THE ENGINE SEEMS TO RUN UNEVEN OR TAKES A WHILE BEFORE IT TICK`S OVER EVENLY ALL THE CAM GEAR IS NICE AND QUIERT AS IT SHOULD BE IVE DONE A COMPRESSION TEST ON ALL 4 CYLINDERS AND THEY ARE ABOUT 130 PSI OR WITHIN A FEW POUNDS OF EACH OTHER AND SOMTIMES THE LEFT HAND CYLINDER POST WHEN FIRST STARTED OR UNTIL I CLEAN THE PLUG ON FIRST START UP I CAN SMELL BURNING ENGINE OIL BUT WITH NO BLUE SMOKE TO SPEAK OF ALL CARBS ARE BALANCED AND TIMING IS SPOT ON
CHEERS IN ADVANCE
BARRIE
P.S. ANYONE IN THE MIDDLESBROUGH AREA WHO KNOWS ABOUT ZED`S
Z900 A4 ENGINE PROBLEM
phil churchett
Hi Barrie,
it may help if you could let us know the following;
How many miles has it done?
Has it been like this since you first owned it?
Does this happen on every start-up?
Does it have a standard air-box and exhaust?
Does it run/start OK once you have cleaned the l/h plug?
Once you have posted a reply to the above, i am sure some of us can come up with a few things to try
BARRIE`S Z1
- DogsbolloxofZ1B
phil churchett
I did have this problem several years ago, but only when i left the bike on the side stand. Now, when it's in the garage, i always put it on the centre stand.
Hey presto, no problem.
Some people have a theory that while it's on the side stand, oil runs to the l/h side of the engine, resulting in the problem you have.
Barry, I had a similar problem, took me a year to find.
I noticed one day after pulling the carb bowls off that two were very clean (not used much). These two were, (you guessed it!) served by the same fuel line.
Further inspect showed that this fuel line was partially blocked at the cock, where the inner part of the line had doubled up on itself. It had limited power at the start, however would run OK on a trip. I used to replace spark plugs, thinking that was the problem. I could imagine it giving a similar problem with just a one line system.
