oil leaking from shifter
GregZ
#1 PostAuthor: GregZ » Tue Mar 24, 2009 10:50 pm
I'm sure this is easy fix. I have oil leaking from shifter area. Is there a o-ring or seal ??? part #
thanks
gregz
Z1
1965 Corvette
wilsonsjw11
#2 PostAuthor: wilsonsjw11 » Wed Mar 25, 2009 6:02 am
Greg
There is an oil seal in the transmission cover part No 92049-004.it is where the gear change LEVER ASSY exits the engine.
You may require a transmission cover gasket too,part no 14085-004.Remove the left hand engine cover to gain access.
Regards
Steve
Steve Cooke
#3 PostAuthor: Steve Cooke » Wed Mar 25, 2009 7:40 am
There is also an o-ring behind the distance collar behind the engine sprocket I dont know how much use it is but it's there.
