Tank Repair
bakey
Tank Repair
#1 PostAuthor: bakey » Fri Mar 27, 2009 10:17 am
Hi guys
wondered if any of you have used that epoxy stuff for tank repair? Is there a better brand etc to go for and is it very difficult?
I dont even think the tank from my spare paint set has a leak but while it is off and dry, im thinking this is probably a good time to protect it etc.
Also, when it comes to decals for the A4 tank. Were is a good place to go for them?
''Who's motorcycle is this?''
Garn 1
#2 PostAuthor: Garn 1 » Fri Mar 27, 2009 10:35 am
Bakey, if your tank isn't leaking or it hasn't weak spots due to rust, my advice is don't use these tank lining epoxies. Whereas, there are good products on the market "If it ain't broke, don't fix it'. I've seen some tanks with the lining lifted and that is a mess.
KZCol
#3 PostAuthor: KZCol » Fri Mar 27, 2009 10:47 am
I used the tank repair kit from Frosts with good results if it's any help.
Cheer
Col.
london calling
#4 PostAuthor: london calling » Fri Mar 27, 2009 2:37 pm
For decals you want
THE IMAGE WORKS,
TEL:0115 944 3111 and speak to Graham :wink: :D
www.the-image-works.co.uk
Jack
KWACKERZ1
#5 PostAuthor: KWACKERZ1 » Fri Mar 27, 2009 4:25 pm
Frosts do good stuff but if its ok leave it as is, Just remember when storing the bike for a while leave the tank full it stops the moisture and corrosion then.
Redbeard
#6 PostAuthor: Redbeard » Mon Mar 30, 2009 6:17 pm
bakey I'm about to use that epoxy stuff, i think halfords do it, cos my tank has a tiny hole (not visible) where the plate for the fuel sender unit fits to the tank. I'll let you know how i get on. i also flushed/cleaned it with that Frosts kit Kwackerz1 and KZCol mention and it came up pretty good. Didn't use the sealant though because i just wanted to remove the gunk and old fuel. maybe i should have :roll:
1979 Z1000ST
Davy Doherty
#7 PostAuthor: Davy Doherty » Mon Mar 30, 2009 6:33 pm
Im with Garn DON'T us it if you don't have to..
bakey
#8 PostAuthor: bakey » Mon Mar 30, 2009 6:56 pm
good advice lads...if it aint broke :oops:
zedrider
#9 PostAuthor: zedrider » Mon Mar 30, 2009 8:33 pm
ive only ever used petseal . follow the instructions . but i wouldent use it till you realy need too .
zed
