Ammeter on Z1R
ted1r
Ammeter on Z1R
#1 PostAuthor: ted1r » Sun Apr 05, 2009 7:33 pm
If as in my case the ammeter has been replaced with a voltmeter would this have any effect on the charging system?as I keep having problems and melting fuses ,not blowing them just melting them.
'Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
tlc
#2 PostAuthor: tlc » Sun Apr 05, 2009 8:27 pm
Ted.
It shouldn`t make a difference unless it has a much larger resistance than original.
Can I suggest you get an voltmeter / tester with a 10amp current setting and connect this from the battery to the main lead once you have disconnected it. This will then show you what you are drawing as you turn each circuit on. You could disconnect the voltmeter on your bike to discount this but from what you describe you are drawing a lot of current but not enough to blow the fuse.
My old fuse box was a bit rough and had started to melt the plastic that held the fuses in place. New fuse box and end of problem.
As a guide main beam at 60watts = 5 amp draw. (60watt divided by 12 volts = 5 amps) You can then check each circuit to find which is drawing too high and at least isolate that circuit. Then find higher than required resistance in wiring or unit or whatever?
ted1r
Ammeter on Z1R
#3 PostAuthor: ted1r » Mon Apr 06, 2009 7:18 am
Thanks Chris will go now to the garage and fiddle.
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
tlc
#4 PostAuthor: tlc » Wed Apr 08, 2009 8:49 pm
Ted.
Love to know what it was in the end ?
ted1r
post
#5 PostAuthor: ted1r » Thu Apr 09, 2009 1:17 am
It can only be traced to a multitude of things that the Italian who owned this first thought was a good repair,fingers xed its sorted. thanks.
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
ted1r
post
#6 PostAuthor: ted1r » Thu Apr 09, 2009 1:31 pm
Right for benefit of TLC and all others who give a dam :lol: :lol: I can report that Z1R went fine last night touch wood I have got it sorted,many thanks to all helpers and advisers and see you all at the Ace.
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
Users browsing this forum: knut and 48 guests
