Z1A wiring
- RALPHARAMA
Z1A wiring
I have a manual for a Z1 but not the Z1A I am working at the moment. I have to cure some wiring issues; does anyone know if there were any wiring changes from the Z1 to the Z1A
Ralph Ferrand
Vduk, the only differences in the Z1 & Z1A wiring, that I know of, is with that Brake light outage "gizmo". The unit is under the tank on a bracket mounted off the LHS coil. It is wired to the light in the Tacho. The Z1 does not have that particular outlet and connection on the main harness.
- mick znone
im away from home until 14th Ralf, my bike is a z1a, i have haynes,clymer and zpower parts book at home, could send any of those up [if any help], but only when i get back.
- RALPHARAMA
Thankx ladz.
I have to fit a new pattern reg/rec so if the charging part is the same it'll be plain sailing from the Z1 wiring diagram. The owner of the bike has just told me that he has a Haynes manual which presumably will have the correct diagram?
Many thanx for the offers
Ralph Ferrand
- RALPHARAMA
Ralph Ferrand
