Z1A wiring
RALPHARAMA
Z1A wiring
#1 PostAuthor: RALPHARAMA » Mon Apr 06, 2009 10:29 pm
I have a manual for a Z1 but not the Z1A I am working at the moment. I have to cure some wiring issues; does anyone know if there were any wiring changes from the Z1 to the Z1A :?:
Ralph Ferrand
Garn 1
#2 PostAuthor: Garn 1 » Mon Apr 06, 2009 11:40 pm
Vduk, the only differences in the Z1 & Z1A wiring, that I know of, is with that Brake light outage "gizmo". The unit is under the tank on a bracket mounted off the LHS coil. It is wired to the light in the Tacho. The Z1 does not have that particular outlet and connection on the main harness.
mick znone
#3 PostAuthor: mick znone » Tue Apr 07, 2009 7:05 am
im away from home until 14th Ralf, my bike is a z1a, i have haynes,clymer and zpower parts book at home, could send any of those up [if any help], but only when i get back.
phil churchett
#4 PostAuthor: phil churchett » Tue Apr 07, 2009 8:42 am
Ralph, if you don't have any luck, i can send you a colour wiring diagram for Z1A, or lend you a gen manual, you can then copy the other wiring diagrams for future reference.
RALPHARAMA
#5 PostAuthor: RALPHARAMA » Tue Apr 07, 2009 10:12 am
Thankx ladz.
I have to fit a new pattern reg/rec so if the charging part is the same it'll be plain sailing from the Z1 wiring diagram. The owner of the bike has just told me that he has a Haynes manual which presumably will have the correct diagram?
Many thanx for the offers :lol:
Ralph Ferrand
#6 PostAuthor: chrisu » Tue Apr 07, 2009 10:32 am
Haynes correct ?
There's an optimist. They don't call it the book of lies for nothing.........
RALPHARAMA
#7 PostAuthor: RALPHARAMA » Tue Apr 07, 2009 11:18 am
:hys
Ralph Ferrand
