Desperate to identify these !!!
Z1B Alan
#1 PostAuthor: Z1B Alan » Sun Apr 12, 2009 6:16 pm
I am still desperate to identify which carbs are fitted to my bike, kindly view the photos and suggest which model they are from. Currently running 115 mains and 15 pilot jets my problem is they don't seem to match any listed in the Clymer manual with the current jetting.
Hope the photo of the tickover adjusment helps with identifing which carbs these are that are fitted to my bike.
I would also once identification has been made need advice on correct jetting when fitted to a standard Z1B
PJ
#2 PostAuthor: PJ » Sun Apr 12, 2009 6:30 pm
They look like 26mm z1000 carbs - but the tickover adj on the bottom?
mikey
#3 PostAuthor: mikey » Sun Apr 12, 2009 6:32 pm
Im most probably wrong but with tickover adjuster on the bottom they look like the carbs that were on my GS1000
tlc
#4 PostAuthor: tlc » Sun Apr 12, 2009 6:34 pm
Airscrew on the side. Z900A4 ?
foreverinthegarage
#5 PostAuthor: foreverinthegarage » Sun Apr 12, 2009 6:35 pm
Z1R has the tickover adjuster on the bottom
Z1000 The King Is Still Alive.
zedrider
Re: Desperate to identify these !!!
#6 PostAuthor: zedrider » Sun Apr 12, 2009 6:36 pm
Z1B Alan wrote:I am still desperate to identify which carbs are fitted to my bike, kindly view the photos and suggest which model they are from. Currently running 115 mains and 15 pilot jets my problem is they don't seem to match any listed in the Clymer manual with the current jetting.
try Nrp www.nrp-carbs.com
zed
ted1r
post
#7 PostAuthor: ted1r » Sun Apr 12, 2009 6:36 pm
Sticking me neck out 28mm Z1r
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
000zeds
#8 PostAuthor: 000zeds » Sun Apr 12, 2009 6:37 pm
Possibly from a Z1000 MK11
Zeds-R-Us
#9 PostAuthor: PAULJAC47 » Sun Apr 12, 2009 6:37 pm
Look like the carbs fitted to early Suzuki gs850/1000 will work fine if you are not bothered with original fitment Cheers Paulj....
#10 PostAuthor: chrisu » Sun Apr 12, 2009 6:38 pm
agree - Z1R carbs
sweptail
#11 PostAuthor: sweptail » Sun Apr 12, 2009 6:39 pm
26mm z1000a1 me thinks. Z1b usually runs 28mm. :)
ted1r
post
#12 PostAuthor: ted1r » Sun Apr 12, 2009 6:41 pm
WHOOOO got sumfink right
Ted
:D
KE250
KZ1200
Puch Maxi
and me ol Granada
#13 PostAuthor: PAULJAC47 » Sun Apr 12, 2009 6:43 pm
Just looked in Gs1000 manual these carbs are the same as fitted with adjuster underneath!!!
hillbilly
#14 PostAuthor: hillbilly » Sun Apr 12, 2009 7:11 pm
i have a set like that,and they are off a gs1000.hope it helps.
zeroed
#15 PostAuthor: zeroed » Sun Apr 12, 2009 8:57 pm
look the same as ones on my Z1000a1 26mm(maybe 28mm?) tho that`s an educated guess, i`m no expert
