No spark-update
Robw
No spark-update
#1 PostAuthor: Robw » Thu Apr 16, 2009 4:21 pm
I have been checking the ignition system as I have no spark. Using the fault finding chart, the pulsar coil resistance reads correctly on 1 and 4, but no ohms on 2 and 3.
Also the IC Ignitor seems to have the wrong resistance, having looked at the prices to replace them, would a Dyna s kit replace them both. I already have Dyna coils and leads fitted.
It is for a Z1000J
Cheers Rob
#2 PostAuthor: Pigford » Thu Apr 16, 2009 8:45 pm
Yes Dyna S is an easy replacement... gets rid of the igniter....
I have a used/working std igniter up for grabs if any help? Off me Lawson :wink:
PM me if you're interested :!:
#3 PostAuthor: paul doran » Thu Apr 16, 2009 10:31 pm
Pigford wrote:Yes Dyna S is an easy replacement... gets rid of the igniter....
is it free Mark
go on be a devil offer it for free
as you allway's get stuff for free return the favour
Robw
#4 PostAuthor: Robw » Fri Apr 17, 2009 7:32 am
Piggy, you have a pm.
Rob
#5 PostAuthor: Rich » Fri Apr 17, 2009 6:51 pm
If you have 2.2 ohm coils check a dyna s will run them
Robw
#6 PostAuthor: Robw » Fri Apr 17, 2009 7:20 pm
Just checked my coils I have the green 3 ohms DC1-1 coils fitted, will these be okay to use with standard ignitor and Dyna DS2-1 ignition.
Cheers Rob
#7 PostAuthor: Pigford » Fri Apr 17, 2009 7:44 pm
I'm running me Lawson with only the Dyna S..... :shock:
The igniter is not used :!:
Thats the idea, to replace the Kawasaki CDI box thingy, with a simpler and more reliable item :wink:
#8 PostAuthor: Rich » Fri Apr 17, 2009 7:52 pm
Check the connector block terminals before spending your money as it is these that usually give trouble.
Robw
#9 PostAuthor: Robw » Fri Apr 17, 2009 7:58 pm
I have checked the wires near the bottom using the pin adapters on my fluke, they read the same.
Piggy I have had a look on the Dyna website and see what you mean. I will still take you up on your offer as it gives me the option of running standard and having a tacho working.
I will contact John Browse tomorrow and see how much a second hand pulse coil is.
Cheers Rob
#10 PostAuthor: Pigford » Fri Apr 17, 2009 8:02 pm
OK Rob, will post Monday matey......
Robw
#11 PostAuthor: Robw » Fri Apr 17, 2009 8:55 pm
Cheers Rob
Robw
#12 PostAuthor: Robw » Fri Apr 24, 2009 7:34 pm
Result, thanks to Pigford and John Browse I have replaced the offending items and now have a big fat juicy spark from both coils :lol: . I should get my carbs in the next couple of weeks, so it is on time for it to be ready for June.
A happy Rob
Geoff Meager
#13 PostAuthor: Geoff Meager » Fri Apr 24, 2009 10:02 pm
Thats great news Rob ..... hopefully see you soon then ?
