Need 2 front discs for a z900a4. 4 bolt fixing and 290mm.
Mine are down to 4.9mm thick! HELP.
z900a4 front discs
Hi,
i think there are two thickness of disks for the Z900 depending whether you have a KZ900 or a Z900, as far a i know the the KZ900 in the USA has 6mm and i am pretty sure the UK had 4.5mm.
the KZ900 only had a single disk fitted and the Z900 in the UK had twin from disks.
i may be wrong though....
Ian, i think i may be able to help you, i'll get back to you shortly
Gary
Gary
