hot,hot leads
mick znone
hot,hot leads
#1 PostAuthor: mick znone » Sun Apr 26, 2009 6:02 pm
another problem guys :bawl took the bike out for 7 miles,[first run this year] ran very well. has new denso plugs. i have put the combined reg/rec from zpower on. got back, the ht leads were really hot and there was smoke coing from under the tank. :cry: :?: :cry: :?: ive done something wrong.
zedrider
#2 PostAuthor: zedrider » Sun Apr 26, 2009 6:08 pm
the only thing i can think of is coils from eletronic ignition used on points ignition or the coils are + earth instead of - earth . both will make the coils hot .
zed
mick znone
#3 PostAuthor: mick znone » Sun Apr 26, 2009 6:13 pm
standard points, coils and leads at the moment and going by my electrical work today, they are staying that way :cry:
ash
#4 PostAuthor: ash » Sun Apr 26, 2009 6:42 pm
Mick are the coils getting hot as well as the leads,
mick znone
#5 PostAuthor: mick znone » Sun Apr 26, 2009 7:11 pm
ash wrote:Mick are the coils getting hot as well as the leads,
not sure on that one. unhealthy amount of smoke coming from under the tank though. ive replaced the old set up for now. the bike then ticked over ok.
ash
#6 PostAuthor: ash » Sun Apr 26, 2009 7:43 pm
I suppose if everything has been changed to accommodate the new set up then everything shud be ok, iv found in the past mixing electrical old with new can cause some probs, even down to the old loom, iv done loads of old zeds up and the amount of melted electrics due to just adding half whats needed cause so much shit, i just love these old zeds, what therapeutic joy they bring,
Good luck anyways,
Garn 1
#7 PostAuthor: Garn 1 » Sun Apr 26, 2009 8:49 pm
The smoke coming from under tank, will probably be the coils melting and ozing some goo. This is usually the symtom of over-voltage to the coils.
After you fitted the combined reg/rec, did you check to see if the regulator part is working? Otherwise, you have may have wired the unit incorrectly.
This checking is done by simply checking the voltage across the battery terminals with the engine running at about 3-4000 rpm. Should not be more than 14.5Volts. .... RegardZ.
Z.O.A
Re: hot,hot leads
#8 PostAuthor: Z.O.A » Sun Apr 26, 2009 8:52 pm
mick z1a wrote:another problem guys :bawl took the bike out for 7 miles,[first run this year] ran very well. has new denso plugs. i have put the combined reg/rec from zpower on. got back, the ht leads were really hot and there was smoke coing from under the tank. :cry: :?: :cry: :?: ive done something wrong.
I know this might sound silly but is it possible that maybe some oil residue got on the motor or header pipes, ie from rocker cover or leaky tacho cable seal, it 'd smoke like hell as it was being burned off, just a suggestion.
mick znone
#9 PostAuthor: mick znone » Sun Apr 26, 2009 9:06 pm
well guys, i dont have a volage checker, mainly because i dont know anything about electrics. i know this sounds negative, buts its true, think i need to learn a bit.
i did think the smoke could have been a bit of residue oil/grease, but the leads were hot and very limp, is that normal?
#10 PostAuthor: Pigford » Mon Apr 27, 2009 9:09 am
Heat from the motor will make leads HOT & limp......
If its still running OK sit and watch it (with an extinguisher handy) & see if it is just excess oil residue from the rebuild!
I have never heard of HT leads burning due to electric fault :??
mick znone
#11 PostAuthor: mick znone » Mon Apr 27, 2009 9:18 am
i am going to take the bike out in a bit to see ifit gets just as hot with the old set up. i am now wondering if it was residue oil/grease from storage.
hillbilly
#12 PostAuthor: hillbilly » Mon Apr 27, 2009 11:47 am
you shud be able to smell the difference between oil burning,and rubber,dont furget the extinguisher though. :lol:
mick znone
#13 PostAuthor: mick znone » Mon Apr 27, 2009 2:52 pm
took it out today 30 miles, no problem, [except the rain] it ran fine with the original set up. i do however want to put the new gear on sometime.
whilst out i bought a multi tester, tomorrow i will do the across the battery test ive heard mentioned.
#14 PostAuthor: Rich » Mon Apr 27, 2009 5:58 pm
I'd put it down to oil / header pipes. Pull the tank off and if you see signs of melting in the loom then worry but I doubt you will.
mick znone
#15 PostAuthor: mick znone » Mon Apr 27, 2009 9:55 pm
well, i have to say, with the combined re/reg unit on the way id connected it ......IE block connection to block connector, black earth behind kick start, one white wire with double female, receiving wire with fuse from battery and one wire that i thought was coming from the generator..... there was an unhealthy looking amount of smoke coming from under the tank and the ht leads were hot soft and limp as f;ck.
confidence lost :ooops
