z1000 mk11 cast wheels fit z1000a1?
gordon62
#1 PostAuthor: gordon62 » Wed Apr 29, 2009 10:15 am
Hi all,
just spoted a set of cast wheels from a z1000 mk11, and I"m sure they will fit my z1000a1,they are 4 bolt for discs, so wanted to ask if anyone knows for sure,
cheers,
Andy
KWACKERZ1
Wheels,
#2 PostAuthor: KWACKERZ1 » Wed Apr 29, 2009 2:24 pm
Front definitley and the back should be the same but check your spacer lengths and that the wheel tightens up ok, as some caliper to wheel spacers are different. (e.g ltds)
But I have used a1 wheels in a mk11 and vice versa.
000zeds
#3 PostAuthor: 000zeds » Wed Apr 29, 2009 7:05 pm
I think the cush drive / sprocket carrier are different as i put a set from a Z1000A2 on to a Z1000A1.
Zeds-R-Us
KWACKERZ1
#4 PostAuthor: KWACKERZ1 » Wed Apr 29, 2009 8:10 pm
I was working on the assumption the wheels came complete with cush drive two zeds could be right.
I know I have moved cush drives sucesfully between spoke and aftermarket mags no problem, but have never done it between std kwack mags.
000zeds
#5 PostAuthor: 000zeds » Wed Apr 29, 2009 8:22 pm
Make sure you get the cush drive /sprocket carrier + collar for axle {left side} with MK11 wheels !
Zeds-R-Us
