gpz1100 engine/z1000 frame
gazza
#1 PostAuthor: gazza » Sun Feb 04, 2007 7:38 pm
Hi , i have a z1000a2 frame and will be puting a gpz1100 engine into her any mods i need to do before i start,
big green bus
#2 PostAuthor: big green bus » Sun Feb 04, 2007 9:04 pm
the gpz1100 engine mounts different to the earlier bikes it has one rear mount and two front. the other has two rear and one front so you will need to change mount i would use gpz crankcases to save pissing about
big green bus
#3 PostAuthor: big green bus » Sun Feb 04, 2007 9:07 pm
me again sorry i meant 1000 crankcases, (i have had a can)
FLC
#4 PostAuthor: FLC » Sun Feb 04, 2007 9:31 pm
i put one in a 76 frame , i had to cut off the underside mounts of the frame (ones with pear shaped nuts) and make new front lower mounts, top rear and top front i remade in alloy although i could have used a mix match of the ones i had. also the rear spacers from the 11 needed turning down, the top rear bolt on the eleven is a larger dia. but a fairly easy swap. the 11 motors are shorter due to not having kick start casing. the kick start Z's wont go in a unitrac frame (dont ask how i know this).
london calling
#5 PostAuthor: london calling » Mon Feb 05, 2007 2:31 am
Steve, was it a 25 litre can??
Jack
gazza
GPZ1100 / Z1000A2
#6 PostAuthor: gazza » Mon Feb 05, 2007 8:41 pm
THANKS FOR YOUR REPLY'S WILL HAVE A GOOD THINK ABOUT THE BEST THING TO DO OVER A FEW PINTS
