z900 oval light fit z1000?
gordon62
#1 PostAuthor: gordon62 » Mon May 11, 2009 7:15 pm
Hi all,
I bought a z900 rear oval light a little while back to put on my z1000, only it doesnt fit, the holes are about 1mm or so out, am I correct in saying that I will need the z900 light bracket to fit this light,
Andy
bedlow1
#2 PostAuthor: bedlow1 » Mon May 11, 2009 7:23 pm
Andy the Z900 had a square rear light. The ovals were found on Z1,Z1A,Z1B which had a different bracket
1972 Z1 Euro Spec
1975 Z1B UK Bike
Davy Doherty
#3 PostAuthor: Davy Doherty » Mon May 11, 2009 7:24 pm
The oval tail light is Z1/A/B The square one is Z9
gordon62
#4 PostAuthor: gordon62 » Mon May 11, 2009 7:35 pm
Hi,
thanks, I had a feeling that was the case, I want to change the square one on my z1000 to the z1 oval, will have to get a bracket,
cheers,
Andy
phil churchett
#5 PostAuthor: phil churchett » Mon May 11, 2009 7:46 pm
There is also a difference between the brackets for the UK and USA mudguards.
Garn 1
#6 PostAuthor: Garn 1 » Tue May 12, 2009 3:23 am
Phil, as I understand there are two types of mount for each of the the following:
    the [Oval] Z1 series.
    the [Square] Z900 A4, Z1000 A1 & 2.
Both are for the two different types of rear guard [short or long]. I must admit I have seen others that support the oval lens, however, I thought they were form different models (650 etc). Not sure about Ltd mounts of both classes.
mikey
#7 PostAuthor: mikey » Tue May 12, 2009 7:53 am
Dont know much about all these difrent models etc, but when i bought my Z1000A2 it had the oval light on it with a short rear mudguard, there does seem to be an extra couple holes in the mudguard near the light bracket and the rear light to me seems to sit a bit low?
bunnysZ
Granny Magnet
#8 PostAuthor: bunnysZ » Tue May 12, 2009 3:17 pm
had a sq light on my z1000a2 changed it to an oval light , just drilled out one of the holes a bit wider , doesn't notice when the light is on, and still able to put sq light back on if i want to.
