Can anyone give me a clue as to the length of the four drain pipes from the float bowls on a Z1B. I don't want to wait until I have the carbs fitted before I measure them.
Also the two breather pipes, where are they routed to when they leave the carbs.
Thanks for any help.
Z1B Carb drain pipes
PaulMceleney
- Chunks
PaulMceleney
- Chunks
DurhamZ1B, the usual length of these drain pipes are a bit longer than you think, as they are suppose to not squirt onto the rear tyre and not drip on the exhaust. You will find with a bit of allowance you will need at least 2.5 meters for the four of them.
The two breathers tubes, on the Z1B, pass thru the oval hole and lay near the airbox grill.
A little story about these drain tubes. Unbeknowns to me, on a long run, I had fuel pouring out of these tubes onto my rear tyre. I turned into a service station, as I thought a "top-up" would be a good idea. As I turned into the station, I noticed some grease on the entrance. You guessed it! As I turned, the back went out a few feet as the petrol had soaked the tyre at slow speed and that, with the grease, I was all over the drive. Managed to save her. However, I now always have those little tubes poking out the right hand side.... RegardZ.
Hi Durham,
The four pipes should pass through a rubber ring thingy that is fitted over the engine mount spacer on the right rear side, the one behind the kickstart. Its called a 'clamp', overflow, in the parts book, number 92037-134 They need to be long enough to go below the trye in case off leaks like GARN says.
this is what the rubber looks like
https://www.z-power.co.uk/merchantmanag ... 4&x=8&y=10
