Z650 Part
steve
Z650 Part
#1 PostAuthor: steve » Mon May 25, 2009 7:44 pm
I'm in the process of dismantling my Z650 front forks and can't stop the damper from spinning while turning the allen head bolt at the bottom of the lower fork leg...therefore, I could really do with either borrowing or buying the adapter piece that holds the damper in place. The part no is 57001-1011.
Would appreciate it if anyone can help.
Steve
#2 PostAuthor: Pigford » Mon May 25, 2009 7:53 pm
Whittle the end of a broom handle at about 45degs.... leave a blunt end about size of a 5pence, then ram it down the fork onto the damper.... Clamp the broom handle in a vice and undo the bolt :wink:
compo z1r
forks
#3 PostAuthor: compo z1r » Mon May 25, 2009 8:48 pm
Pigford wrote:Whittle the end of a broom handle at about 45degs.... leave a blunt end about size of a 5pence, then ram it down the fork onto the damper.... Clamp the broom handle in a vice and undo the bolt :wink:
so thats y' all my' brushes are knackered :lol: :lol: :lol: :lol:
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
Keefleaf
#4 PostAuthor: Keefleaf » Tue May 26, 2009 9:52 am
Maybe try a "Windygun" at local garage,plus broomhandle wedge.
mothra
#5 PostAuthor: mothra » Tue May 26, 2009 10:36 am
I found with my z650 forks a impact driver (as keefleef suggested) was all I needed - 5 seconds each and all sorted. Got to be worth popping into a local garage...
Currently restoring a 78 z650
KWACKERZ1
gator grip is what you need!
#6 PostAuthor: KWACKERZ1 » Tue May 26, 2009 11:27 am
What you need is a Gator grip socket they are cheap and it looks like a spark plug sicket and has loads of roller like needles inside that will grip a rounded nut.
I have found these better than the proper kawasaki tool.
http://www.amazon.com/Gator-Grip-ETC-20 ... B000065CJ8
