z1000A2 carbs
paulstrees
z1000A2 carbs
#1 PostAuthor: paulstrees » Tue May 26, 2009 7:23 pm
Is the vacuum take off for the fuel tap on the carbs or was it taken off no2 cylinder rubber like on a gs1000 suzuki
m1ks
#2 PostAuthor: m1ks » Tue May 26, 2009 7:27 pm
The vacuum takeoff on mine is off carb 2, (mines a Z650 however but if your Z1 uses the same Mikuni slides it should apply)
Hope that helps some?
bunnysZ
Granny Magnet
#3 PostAuthor: bunnysZ » Tue May 26, 2009 7:32 pm
yes its off the carb, between 2 and 3
