Z1B STEERING DAMPER
martinz1b
Z1B STEERING DAMPER
#1 PostAuthor: martinz1b » Thu May 28, 2009 6:15 pm
Can anyone remind me if the original steering damper fits straight onto the bottom yolk without a bracket, I can't remember seeing a bracket but have been told I need one.
Thanks for any advice
Mart
steve bowdler
#2 PostAuthor: steve bowdler » Thu May 28, 2009 6:51 pm
If you have the z1000 you will need a bracket if you have the 900 I beleive there is a hole ready for the damper . Come on you 900 owners help me out :roll:
martinz1b
#3 PostAuthor: martinz1b » Thu May 28, 2009 7:29 pm
Ah, I must have been given duff info, I seem to remember it going onto the underside of the yolk but that was going on 20 years ago :mi
Z.O.A
#4 PostAuthor: Z.O.A » Thu May 28, 2009 7:30 pm
martinz1b
#5 PostAuthor: martinz1b » Thu May 28, 2009 7:38 pm
Thanks lads, now I have seen that picture I definitely know I didn't have a bracket when it was on the bike.
mick znone
#6 PostAuthor: mick znone » Thu May 28, 2009 9:25 pm
straight onto the bottom yoke on the z1a :D
Garn 1
#7 PostAuthor: Garn 1 » Thu May 28, 2009 9:48 pm
DurhamZ1B. I think you have resolved your problem, however, just in case you haven't. All the Z1, Z1A and Z1B's have the bottom yoke of the triple tree, with a boss that is drilled with a 8mm clearance hole, to take damper. Z900 & Z1000 do not have this hole, however, it may be drilled, in this bottom yoke to facilitate a damper.
Make sure you have the bracket on the RHS downtube of the Z1B frame, that takes the other end of the damper. Many are broken-off and filed smooth and painted.
As a foot-note: This down-tube bracket is often broken off, as a result of the steering damper seizing-up and causing the bracket to break and can cause damage to the head fins.
martinz1b
#8 PostAuthor: martinz1b » Thu May 28, 2009 9:56 pm
Thanks, I had mine re-welded back to the frame many moons ago after the problem you mentioned, but I didn't know that it could cause fin damage. I will keep this in mind.
Thanks also Mick.
Mart
mick znone
#9 PostAuthor: mick znone » Fri May 29, 2009 6:41 am
thanks also to Garn for seizing advice, i too will keep an eye on it.
Users browsing this forum: Bing [Bot] and 44 guests
