Z1000R throttle cable routing
martinz1000r
#1 PostAuthor: martinz1000r » Fri May 29, 2009 1:47 pm
Should the cable (cables in my case as RS36 fitted) run above or below the spine of the frame where the coils are mounted?
#2 PostAuthor: chrisNI » Sat May 30, 2009 1:02 am
Off the top of my head I think it goes down the side above the frame and dips down through behind the coils. Haven't been in there in almost exactly a year so it's a bit fuzzy but I think that's right.
