One for the Zed experts.....is there a ball bearing between the slotted threaded clutch adjuster and the push rod ?
On my bike, there is not...on Dave James' bike there is one , and it seems to be messing up the adjustment .
( I should add that the adjuster stud on dave's bike seems to have been fabricated from a cut off piece of bolt ).
I've looked gthrough the Kawsaki manual , but can't find a detail shot / drawing or explanation.
Thanks in advance. Loz
Z1A clutch release mechanism
He who dies with the most toys wins .
The ball bearing is on the clutch end off the pushrod. The outer clutch release ( the round threaded thing ) has the clutch pushrod fitted directly into it. You can pull out the pushrod and the ball bearing will stay on the end off the clutch pusher. Only way to get at the ball bearing is to remove the clutch cover etc.
Theres a picture off it in zpowers parts book
I have a spare, used pushrod that dave's welcome to if his is to short,
Thanks for the replies guys. Peter, great suggestion...Dave Marsden's little parts list book
My question was slightly misleading.... I literally meant a single ball was positioned between the adjuster screw and the push rod...don't know why except I think the home-made adjuster screw was too short.
All fixed now, ( ball removed ) and can actually adjust the clutch again.
Users browsing this forum: Bing [Bot] and 60 guests
