Damaged Fin Repair
Hack
#1 PostAuthor: Hack » Sat May 20, 2006 8:25 pm
Broke a small piece of fin off the cylinder block whilst removing the head.
I'm really p*ss*d off because I was being very careful, anyway as I have the loose piece and it fits back exactly I wondered if it can be invisibly repaired, i.e. welded?
If so does anyone know of anywhere in the Midlands that can do it and how much it is likely to cost - failing that it's good old Ebay for a used block!
I'm feeling pretty dumb at the moment!!
Andy
Hobbo
International Rep
#2 PostAuthor: Hobbo » Sat May 20, 2006 8:31 pm
HI THERE HACK
WERE ABOUTS ARE YOU COUPLE OF LADS AT MY SPOT HAVE DONE REALY NICE FIN REPAIR JOBS FOR ME. I AM IN HULL YORKSHIRE
PHIL
Hack
#3 PostAuthor: Hack » Sun May 21, 2006 1:16 pm
Phil,
I'm near Lichfield, Staffs.
I was hoping to find someone nearer but if nothing else turns up I suppose I could make a trip up to Hull.
The bit that has broken off is tiny, 20mm x 8mm x 3mm thick, do you think this can be done?
This time of year I was hoping to be on it, not in it, well at least it's raining.
Andy
london calling
#4 PostAuthor: london calling » Sun May 21, 2006 2:51 pm
Andy try SEP at Kegworth,TEL:01509 673295.They are located near the junction of the M1/24 and the A50 by-pass.I would say they are about 45mins-1 hour away from you.
Hack
#5 PostAuthor: Hack » Wed May 24, 2006 4:38 pm
Thanks Jack.
Dropped the block off at SEP yesterday, they seem to think it can be done, will let you know how it turns out.
Andy
london calling
#6 PostAuthor: london calling » Wed May 24, 2006 4:46 pm
Andy,i'm sure the ladz at SEP will do you proud.They've sorted out a few engine cases for me and i couldn't tell which of the damaged mounting lugs they had repaired.
Hack
#7 PostAuthor: Hack » Sat May 27, 2006 10:17 am
Just picked the block up from SEP, they've done a very good job of the weld repair, would definitely recommend them.
Jack, thanks for the tip.
Andy
london calling
#8 PostAuthor: london calling » Sat May 27, 2006 5:10 pm
Andy pleased to hear everything is sorted out to your satisfaction,glad to help out.
The lads at SEP have done my mates and me proud with their engineering skills and they're just down the kermit so itz dead handy as well!!!!!!!!
ollie
#9 PostAuthor: ollie » Sun May 28, 2006 12:44 am
nice one jack ,they are supposed to be very good at crankshafts so ive been told
DogsbolloxofZ1B
#10 PostAuthor: DogsbolloxofZ1B » Sun May 28, 2006 10:06 pm
I hope soooooo just has mine stripped & sorted by them. $ weeks away from firing her up. Can't wait.
ollie
#11 PostAuthor: ollie » Mon May 29, 2006 12:34 am
nothing quite like it mike is there,firing them up for the first time ,esp that zed of yours ,you had much intrest in it ?
#12 PostAuthor: Rich » Mon May 29, 2006 1:58 pm
Did you have the crank welded? How much did it cost?
london calling
#13 PostAuthor: london calling » Mon May 29, 2006 2:12 pm
Ollie,they did a couple of cranks for me a few years back.I put one into a motor for a bike i sold to a mate and has done trouble free 30+K miles and the other is covered in grease waiting to be used.
I know several Classic Z racers who use S.E.P. and are very impressed with their crank work.
Users browsing this forum: moizeau and 41 guests
