Hi
I have a Z1A carb problem.
It is mis-firing, rough running, popping and banging but is better with a bit of choke on.
I have borrowed a set of Z1000 26mm carbs to compare and with the borrowed set it starts easily and runs tons better.
My Z1A carbs have been cleaned by myself with new carb kits, new jets etc.
What i want to know is what is the best stuff/any tricks to use to ensure clean passageways.
It is the first time the bike has run for years.
If cleaned by ultrasonic, how would i know they are really 'clean'? and i wouldnt just be out of pocket?
Any help would be greatly appreciated
John
Z1A Carb problems
PaulMceleney
- Chunks
johnboy
It does sound like fuelling , similar problem with mine 28mm carbs right size jets , i put 26mm carbs on with standard jets ok now , ultrasonic cleaning is well worth it , its a good process and really works , you can make your own cleaner , there was a thread a while back on here on how to make one simple but effective. Are you running with standard pipes , and especialy air filter also
johnboy
- DogsbolloxofZ1B
Users browsing this forum: rpeters and 35 guests
