Hi Guys I have a Z900A4 is there a float height setting without the special tool or a rough start up setting guide or failing that is the tool available to buy?.
Dave Lewis
Float Height
Re: Float Height
DAVE LEWIS wrote:Hi Guys I have a Z900A4 is there a float height setting without the special tool or a rough start up setting guide or failing that is the tool available to buy?.
Dave Lewis
The correct float height for the 26mm carbs on the A4 is 22mm +/- 1mm, turn them upside down and measure from the gaket mating surface to top of float, make sure sure both sides of the float are the same height as well.
DAVE LEWIS
Update
Well completly stripped the carbs today and ultrasonic cleaned the carb bodys and jets rebuilt checked float heights, some needed tweeking.
Have just fitted and fired up first time and runs sweet have just balanced the carbs and ticks over nice.
So £90 on a cleaner well worth it.
Dave L
Dave L
Users browsing this forum: rpeters and 36 guests
