trick z1000
PJ
#316 PostAuthor: PJ » Tue Apr 28, 2009 6:21 pm
I luuurrvv mine
brian 450
#317 PostAuthor: brian 450 » Mon May 11, 2009 9:29 am
Right i have got to get back on track with this build :roll: First thing maybe this week is to get the paint of the engine, Then fit some rear pegs to the frame so i can take the missus on the back then i wont need the Bandit. Finish the bracing off.
#318 PostAuthor: Ginger Bear » Mon May 11, 2009 10:53 am
I think the weather forecast is pant's this week Brian, that should help stop you playing on your new toy & get stuck into this!
brian 450
#319 PostAuthor: brian 450 » Mon Jun 01, 2009 3:10 pm
I know this project has slowed alot at the momment but i have finished the frame bracing now, just got to make some brackets for the rear pegs, then i can get it powder coated :D I am going to start removing the paint from the engine tonight hopefully which is the job i keep putting off because i have really have not got the interest to do it. So i am going to get it over and done with!!! And once i have had my billet engine mounts made it will all systems go and it will be done in no time!!! Pics to follow soon. Off to the TT sun so it will prob be after that.
Monk
#320 PostAuthor: Monk » Sun Jun 07, 2009 8:40 pm
Seat looks great mate, but COME ON !!!!!
I am really wanting to see this finished !!!!!
brian 450
#321 PostAuthor: brian 450 » Wed Jul 01, 2009 9:10 pm
Just a little up date been removing the paint and corosion from the engine it is nearly ready for painting now :D I am thinking of painting it with 2 pack paint like i did on my R1 (which i have just sold :cry: ) but that was water cooled and i never had a problem with it but as this engine is air cooled i am not to sure how it will cope with the heat? I have got a few more brackets to make and weld to the frame then it should be powder coated in a couple of weeks :D Image
brian 450
#322 PostAuthor: brian 450 » Wed Jul 01, 2009 9:11 pm
#323 PostAuthor: Ginger Bear » Wed Jul 01, 2009 9:22 pm
Brian,
I have heard good things about PJ1, I have bought some for me 'Snotter', I believe powdercoating is also up to the job on aircooled engines.
Taffus
#324 PostAuthor: Taffus » Wed Jul 01, 2009 9:23 pm
There was an interesting article in CMM this month on Camcoat...maybe worth giving them a ring?
brian 450
#325 PostAuthor: brian 450 » Tue Jul 07, 2009 8:12 pm
Done a bit to bike this week. When i fitted battery box it was to close to swingarm so i cut the bottom off and made it fit on the top drilled a hole in the side for the banjo bolt to pass through.Image
brian 450
#326 PostAuthor: brian 450 » Tue Jul 07, 2009 8:12 pm
brian 450
#327 PostAuthor: brian 450 » Tue Jul 07, 2009 8:14 pm
brian 450
#328 PostAuthor: brian 450 » Tue Jul 07, 2009 8:15 pm
brian 450
#329 PostAuthor: brian 450 » Tue Jul 07, 2009 8:16 pm
brian 450
#330 PostAuthor: brian 450 » Tue Jul 07, 2009 8:17 pm
