Cam Chain Replacement
I am going to replace the camchain with the link type (Z1R Engine)
If anyone has done this - is there any particular method to withdrawing the old chain, - presumeably with the new chain attached, to draw it through.
I have a chain splitter/riveter so that part of the job should be ok.
Sorry if this task is outlined elsewhere on site but I couldn’t find it.
Kevin
Kevin
post
Hi Kev If it was me I would split the engine and have a look at all the guides and rollers,they are just as important as the chain to be honest.
Ted
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
KE250
KZ1200
Puch Maxi
and me ol Granada
mmmmm……… not what I wanted to hear I’m afraid….. That’s why I got a chain with a link.
The following thoughts come to mind --
I haven’t really got the resources to drop the engine out – ie no garage
Plus …I have kind of promised myself that if I ever drop the engine out, I will get the frame re-coated, - which I have not currently budgeted for.
Plus all the gaskets and new guides etc…. that’s got to be a couple of hundred
Plus while the engine is out I would really have to get it blasted clean and re painted
So my idea of doing a quick and inexpensive afternoons work is mushrooming into a multi million pound winter project !!
I thought this section was ‘Bike Help’ ‘cos this response is definitely not helpful!!!!!
Z1RT311, I don't think you can do thgis task and preserve your valve timing.
In similar circumstances to yourself, I have replaced the chain, by removing the cam shafts, top sprocket and breaking (grinding) the existing chain, so that you have a clear hole for the link, connecting the new chain and threading it around until the new chain is completely around and then discard the old chain and rivet new chain. Re- time engine.
You need room to rivet, an extra hand and a lot of care that you don't drop anything into the sump and you correctly rivet the connecting link. .
RegardZ,
RegardZ,
Pigford, although they often say "split-link", it just means that it is not an "endless chain". In all cases of cam chain I have seen, you still have to rivet the link and there is no little spring keeper! .... As always I reserve the right to be completely wrong!
Can confirm the new chain is to be riveted in place.
This is a pic of the link type to be used.
I appreciate all the advice and may well do a more in-depth job on it at some stage in the future.
For now I think I will take Mr Pigfords route and settle for installing the new chain & see what happens.
Many thanks for all the comments so far.
& thanks Garn1 - I will take out the tensioner
cheers
Kevin
cheers
Kevin
Steve Cooke
- ZedHead
Its been three years since, but i'm fairly sure when i replaced the HYVO on the J1 i used the outer soft link side plate and two short electrical type set screws and half nuts instead of the soft link itself to pull the new chain through.
Not as strong as the soft link proper for this job,..... but no chance of it falling off as it rounds the bottom bend (crank sprocket)
As Steve says a good quality chain, and dont see a problem with a soft link riveted over provided you don't get it too tight!
Hope this helps.
Hope this helps.
Cheers Garn.... can see its a 'soft link' now
Always wondered about fitting a proper 'split link' in a cam chain
seemed a bit dodgy
Suppose the main forces will NOT be trying to force the link plate off, but acting perpendicular to it (lenghtways along the chain) - so in reality, little chance of it coming off
