Harris Magnum 1
Slow progress at the moment........ Now the 5/8" off-set drive sprox are done & collected from Talon,
I asked them to make me up a special sprocket adaptor coz I need a total of 28mm off-set for the 190 section tyre fitted on the Dymag.
I need to set the rear wheel sprox in by 12mm, so they will make a plate to fit where the sprox should live and then I can fit an "off-the-shelf" item to the inboard side of that - and voila, sorted
Once thats done I'll get some 530 H/D chain and the drive line will be complete
All in the c&s effort will be just over £200
I've contacted a chap in Yeovil who powder coated my Mk.II SPrinter and he can do me frame, yokes, s/stand & mounting piece for about £150, so should get that down to him next week - 7 - 10 day turn-around
- ZedHead
paint code
Here you go this is what i have used.
EL KAW 3B VERDE from paints4u.com
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/pb2003.jpg[/img][/img]
- RALPHARAMA
I always feared painting; it is challenging, but well worth the effort. I felt soo good after I did my first paint job. Give it a go.
Ralph Ferrand
vduk wrote:I always feared painting; it is challenging, but well worth the effort. I felt soo good after I did my first paint job. Give it a go.
Trouble is (many-fold).... I've got no equipment;
No spray gun
No compressor
No paint
No room
No talent
No idea
Some may recall my attempt on the Mk.II, with "rattle cans"
'Nuff siad.......
- Ginger Bear
So, finally got the sprocket adaptor from TALON yesterday..... to be polished within an inch of its life
So thats brung it in 12mm - and the drive sprox is out by 5/8" - Jobs a goodun
The adaptor allows fitting of a standard "off-the-shelf" sprox - in this case one for a VRF800
- paul doran
paul doran wrote:lots of ironing I take it Mark
.... my penance is sorting out the w/heater this weekend..... My lads coming up (with his mate) to fit a new mains board & electric water heater, pressurise the system and fit a new pump & 3-way port, etc
Timed it well though, the heating oil is just running out
Following weekend on a short break to Brixham (Devon) for Valentines
