Z1000 Money Muncher
#106 PostAuthor: Ginger Bear » Sat Mar 14, 2009 3:25 pm
Found this yesterday, after i'd been out on it.......
They might look pretty, but they're off. I was gonna re-torque em this morning with a bit of loctite. But checking Me ZX7R manual found they needed a massive 64 ft/lbs of torque, & that would just chew the head off before the torque wrench went 'click'
I have ordered some stainless M10 flanged bolts to do the job, so I should be able to torque em up properly, with a bit of loctite & have no more worries about a 'Full Floating' sprocket! Yes, they were all loose! :oops: :oops:
brian 450
#107 PostAuthor: brian 450 » Sat Mar 14, 2009 3:30 pm
Oh dear that could of been nasty!!!!
mick znone
#108 PostAuthor: mick znone » Sat Mar 14, 2009 3:31 pm
fcuk me Bear, good job you noticed that, else you would have been minced meat, :o
#109 PostAuthor: Ginger Bear » Sat Mar 14, 2009 7:42 pm
Friday the 13th as well!
Don't know if I should feel lucky or not :?
#110 PostAuthor: Rich » Sat Mar 14, 2009 8:23 pm
It's allright they click when they hit the swinger :twisted:
Use nutloc and not threadloc and you're better off with a bolt design cap head instead of the setscrew you have in there.
london calling
#111 PostAuthor: london calling » Sat Mar 14, 2009 9:31 pm
Some chain lube might be a good idea :roll:
Jack
#112 PostAuthor: Pigford » Sat Mar 14, 2009 10:51 pm
GB, forgot to say I checked me sprox.....
15 - 36 630 chain
mikey
#113 PostAuthor: mikey » Sun Mar 15, 2009 12:28 am
Steve (GB) was at my house today helping with tank badges on my Z and guys believe me photos dont do his bike justice you gotta see it in the flesh stunning!!!!!!
#114 PostAuthor: Ginger Bear » Sun Mar 15, 2009 11:07 am
Rich,
What's the difference between threadlock & nutlock?
Piggy,
Thank's for checking your gearing, Seems your final drive ratio is not far from mine. Albeit a little higher. Might try a couple of teeth less on the rear sprocket, will certainly be cheaper. Got me thinking now, if I put a 17 tooth on the front, then that could be too much, I think I'm right thinking one tooth extra on the front is worth two less at the back?? Will speak to Debbens tomorrow.
Jack,
I use a chain wax, which is colourless, & had done less than a 100 miles, so not really got dirty, but I have been out this morning to inspect, and as I type this, the bike is on a paddock stand, with a 'freshly' lubed chain!! :oops: :oops:
maralyn
#115 PostAuthor: maralyn » Sun Mar 15, 2009 11:09 am
Or you could try the belt & braces approach.
http://cgi.ebay.co.uk/KAWASAKI-Z650-Z75 ... 240%3A1318
p.s. I thought the bike looked the dog's, a credit to your work.
Some days I wake up Grumpy.
..................Some days, I just let her sleep.
#116 PostAuthor: Rich » Sun Mar 15, 2009 6:08 pm
Nutloc isn't as strong as threadloc (studloc) and is easier to take out afterwards. It's only there to stop them vibrating out and not glue them in permanently :wink:
#117 PostAuthor: Ginger Bear » Sun Mar 15, 2009 7:41 pm
Nutloc it is then, thanks Rich. I'm off to Ebay to see what I can find.
#118 PostAuthor: Ginger Bear » Sun Mar 15, 2009 8:08 pm
Right, I had a go at 'calibrating' (or seeing how optomistic) my speedo is today.
Strapped on the wife to be's Tom Tom (good n' tight, didn't want to lose that)
Speedo wasn't as far out as I thought. At an indicated 70mph, Tom Tom suggested we were doing 62mph.
What I would like to know is how fast the rest of you are doing at 5000rpm? Tom Tom suggested 64mph, I will post this question in bike help, but feel free to let me know here.
#119 PostAuthor: Pigford » Sun Mar 15, 2009 8:16 pm
Come on GB..............
Zed tacho's are just as accurate as the speedo's :roll:
If you add in there inaccuracy, you may as well not bother this comparison.
My tacho moves slower, the further up the range you get, if you know wot I mean :|
#120 PostAuthor: Ginger Bear » Sun Mar 15, 2009 11:28 pm
I appreciate that Piggy, but I've got to start somewhere. I know none of it will be 'set in stone', but everything is 'out' on this bike , Wheel size, old insruments etc & that doesn't include me! Judging by the comments on the question I asked in the 'bike help' section, I'm about 15mph adrift, which is a great help. I will reduce me rear sprocket by two teeth (after consultation with Debben's) & hopefully I will be sorted. Your own input has been invaluable, It'll be my round next time we meet!
