Pigford's Red Zed - long term projext XYZ
#121 PostAuthor: paul doran » Sun Apr 27, 2008 9:17 pm
Dark Skies wrote:Did you have the crankshaft balanced after the welds were cleaned up?
er what was that about balancing :lol: :lol: :lol:
Dark Skies
#122 PostAuthor: Dark Skies » Sun Apr 27, 2008 10:37 pm
Oh. That doesn't sound ... er ... I'm sure it'll be fine. :)
Nitrous you say?
Hmmm. You should get some balloons in. For medicinal purposes, like. :star
KZ1000-M1 CSR
RALPHARAMA
#123 PostAuthor: RALPHARAMA » Sun Apr 27, 2008 10:45 pm
With Mark's views on brakes, in the unlikely event he actually gets over come with adrenalin and opens the taps, he'll not be able to stop again, so whether the engine shakes itself to pieces or not will be irrelevant. McVities will be ringing the leutine bell :twisted:
Ralph Ferrand
shrekward
#124 PostAuthor: shrekward » Mon Apr 28, 2008 5:40 am
I thought Huntley and Palmers were Mark's sponsors? :??
#125 PostAuthor: Pigford » Mon Apr 28, 2008 6:54 am
Balancings for girls.... :oops:
I don't intend doing long distances on this one, so a few vibes won't hurt :evil:
I didn't have the thick end of £300 for a 'proper job' so I'm gona see wot happens :!:
Guinea - Pigford will report on findings :wink:
RALPHARAMA
#126 PostAuthor: RALPHARAMA » Mon Apr 28, 2008 7:10 am
The balancing of a crank isn't to save the pork being bruised, but to save the engine from being shaken to pieces. If the crank is out of balance then it will fuck it's own bearings and, if far enough out, could even threaten the integrity of the castings holding them. :evil:
If it's been welded by someone unfamiliar with welding cranks, have you checked to see that it hasn't been distorted by the localised heating?
I'm not sure how cranks are balanced. I wonder if it is done dynamically of statically. I would guess that the webs are drilled to balance rather than adding weights :?:
Ralph Ferrand
Dark Skies
#127 PostAuthor: Dark Skies » Mon Apr 28, 2008 7:36 am
I had Chris Appleby do my Z1000-H way back when. It was done dynamically, as I recall - which is why I had to send along the crank with nothing unbolted for a "real world" scenario. Engine ran as sweet as a nut when rebuilt. No vibes anywhere.
KZ1000-M1 CSR
#128 PostAuthor: Pigford » Mon Apr 28, 2008 11:21 am
Hmmmmmmmmmm, OK then, how do you go about static balancing :?:
Can this be done without the use of any SPECIALIZED kit :??
I may be round to yours Ralphy, if we can do this between us :!: :|
If not, suck & see :twisted: :roll:
RALPHARAMA
#129 PostAuthor: RALPHARAMA » Mon Apr 28, 2008 12:54 pm
I've had a quick nose around the winky wanky web and found an absorbing thread on static balancing a triumph crank.
It appears that one needs a set of knife edge beams, accurate scales and a lot of time. To be honest I really don't have the knowledge and certainly don't have the beams :(
I would like to learn how to. I would guess that the beams would be used in conjunction with a surface plate and mine ain't big enough for a zed crank. :(
Ralph Ferrand
Dark Skies
#130 PostAuthor: Dark Skies » Mon Apr 28, 2008 1:00 pm
I'm not sure there's such a thing as static balancing - what purpose would it serve? With something heavy and fast moving like a crank you need to figure out the balance during motion in order to eliminate (as best as one can) harmonics. You're only going to be able to do that by spinning the crank.
When I had mine done I also had the main bearings replaced and new rods and pistons and gudgeon pins put on (so it was all starting out new from scratch). I gather Chris would have assembled the crank without the conrods but with new bearings and the rotor fitted, spun it up and drilled / removed / pressed weights in as appropriate. Presumably the conrods would have been matched up too - otherwise the good work would have been undone. I guess they must then weld it up afterwards - since I recall the rods didn't have split shell bearings and you wouldn't be able to fit them after welding. Not sure how they then take into the account of the welding / balancing.
Here's something on balancing you may find informative:
http://www.rpmmachine.com/engine-balancing.shtml
It amused me that they spelt 'Precision' as "Presicion".
KZ1000-M1 CSR
#131 PostAuthor: chrisu » Mon Apr 28, 2008 3:54 pm
Pigford wrote:Hmmmmmmmmmm, OK then, how do you go about static balancing :?:
:smak
#132 PostAuthor: Pigford » Mon Apr 28, 2008 5:25 pm
I think this is a conspiracy........ :roll:
In other words, when ever an engine is rebored, and a new set of pistons is used, the assembly (crank included) should be balanced... My arse :!:
As Ralphy found out, even Wiseco pistons varied in size by a fair margin, falsing him to get a rebore, matched to the pistons :evil:
I'm gonna whack it back together & give it a blast..... It ain't gonna be revved over 7000rpm that often, so it'll be fine :|
If it was for a race engine, then OK, but.... :wink:
RALPHARAMA
#133 PostAuthor: RALPHARAMA » Mon Apr 28, 2008 9:22 pm
The problem, Piglet, is that having welded it you will have unbalanced the crank. Yes pistons vary a bit, but remember what they are made of ... aluminium a very light material. By welding the crank you will have added filler material, steel, which is heavy, which will make more difference. Truthfully I think that your biggest potential for pain and grief will be distortion as a result of localised heating from the welding process. If I were you I would get your crank sat on a set of vee blocks on a surface plate and clock in the inner bearing surfaces to see if any distortion has been introduced by the welding.
I thought from your earlier pix you were going to give it a NOS habit.
If you weren't tuning this engine why have the crank welded? If you are welding the crank then it's not a matter of just blowing some sparks at it :evil: Soz to bring in reality :(
Tuning is never a cheap game, which is why I leave it alone. It's no good just buying the glamour bitz :evil:
Ralph Ferrand
#134 PostAuthor: Pigford » Tue Apr 29, 2008 6:42 am
........... :twisted: .............. :wink: .............
#135 PostAuthor: paul doran » Tue Apr 29, 2008 4:09 pm
Pigford wrote:Balancings for girls.... :oops:
they will if it explodes :lol: :lol:
Users browsing this forum: j.wilson and 128 guests
