z1100st A1 (re - birth) lots of pics?
freddyz1r
#121 PostAuthor: freddyz1r » Fri Mar 20, 2015 4:29 am
The circlip is out :hoo
oops, got too excited not much else is budging.
The 'plunger' part is definitely 'free', the spring is returning it with great vigour :shock: .
Put it back into soaking mode for the time being, then I'll get a bit more aggressive later :wink:
(A bit worried the plastic 'filler' on the side (( which also is fused in place)) may be the part to surrender first :oops: )
Buying a potential problem (which I've already got) doesn't sit well with me either. I'll just keep at it until something gives way :lol:
cheerz freddy :D
freddyz1r
PUM 329
freddyz1r
#122 PostAuthor: freddyz1r » Fri Mar 20, 2015 4:39 am
Found it much easier to remove the bleed nipple while the hanger was still attached :oops:
Probably should have done this job while still attached to the legs :roll:
freddyz1r
PUM 329
freddyz1r
#123 PostAuthor: freddyz1r » Fri Mar 20, 2015 4:53 am
Hanger separated from the caliper, sliders stripped off . (We are on a roll :P )
Funny how things can get easier with practice :lol:
freddyz1r
PUM 329
freddyz1r
#124 PostAuthor: freddyz1r » Fri Mar 20, 2015 5:04 am
Noticed on this caliper, that the face of the piston has a small amount missing (tried to highlight /make darker the intact part).
Will this make any odds????
My thoughts on it are, theres plenty of flat surface for the back of the pad to sit flush with :?:
freddyz1r
PUM 329
freddyz1r
#125 PostAuthor: freddyz1r » Fri Mar 20, 2015 5:11 am
Piston pushed back with trusty g clamp again
started prepping the calipers for a turn in the blaster :twisted:
(What did I do before the blasting cabinet :?: :roll: )
washers and masking tape (what a strange mixture!)
And of course the hangers before they go in there as well :wink:
freddyz1r
PUM 329
freddyz1r
#126 PostAuthor: freddyz1r » Fri Mar 20, 2015 5:28 am
Now then, the front reservoir is looking quite rough :oops:
removed the brake light wiring, no apparent problems there.
the plunger is moving freely and I can remember the front brake worked a treat :up
freddyz1r
PUM 329
freddyz1r
#127 PostAuthor: freddyz1r » Fri Mar 20, 2015 6:20 am
The screw heads on the reservoir lid were (as expected) chewed up and no purchase could be had :cry:
I weighed up my various options I had to hand :| quite limited :shock:.
while doing this stripdown, my 'black & decker wizard' (dremel) decided not to want to play anymore. So I decided on my next best tool for the job :?: multi-tool cutter, with my smallest metal blade fitted. This proved to be a right handful and left me with not just cuts in the screw heads :oops: but, it had 'scratched' into both sides of each screw head as well
I had previously tried (many years ago) chopping a new 'flat head' into a screw and ended up breaking the lid and thus rendering it useless. But, other than drilling the heads off ( last resort :?: ) I couldn't see any other viable alternative.
freddyz1r
PUM 329
freddyz1r
#128 PostAuthor: freddyz1r » Fri Mar 20, 2015 6:30 am
With the aid of a couple more butchering tools, enough of a 'flat head' was created and success was had :hot :hoo
freddyz1r
PUM 329
freddyz1r
#129 PostAuthor: freddyz1r » Fri Mar 20, 2015 6:25 pm
Calipers and their hangers etc all blasted up :P
IMO they've come out great :xbou
need to sort out what kind of paint etc next, any ideas :?:
freddyz1r
PUM 329
freddyz1r
#130 PostAuthor: freddyz1r » Fri Mar 20, 2015 6:40 pm
The only part that hasn't come out as good as I'd like :x is the front brake reservoir lid.
If you remember, while trying to get the 2 screws out, I put a couple of cuts in the top :oops:
These are still visible :( I could file 'em then re-blast, but I think the paint will fill the scratches up :up
freddyz1r
PUM 329
mick znone
#131 PostAuthor: mick znone » Fri Mar 20, 2015 7:44 pm
i would use p38 body filler to fill the nicks in the reserved lid, trying to use
paint as a filler doesnt always work and its a pain to have to resand and fill later on.
freddyz1r
#132 PostAuthor: freddyz1r » Fri Mar 20, 2015 10:33 pm
Good point mick :up
I've actually got just the thing = that 'qiksteel' stuff :wink: ideal for this job.
cheerz freddy :D
freddyz1r
PUM 329
freddyz1r
#133 PostAuthor: freddyz1r » Fri Mar 20, 2015 11:10 pm
The rear master cylinder has taken a battering :shock:
there are now a couple of pieces that have chipped off, (due to je hitting it too hard :oops: )
It may be game over for this part :cry:
I've left it to soak again, but I think it's too welded. I managed to actually get hold of the end of the circlip, but it just snapped.difficult to get a photo
freddyz1r
PUM 329
freddyz1r
#134 PostAuthor: freddyz1r » Fri Mar 20, 2015 11:28 pm
The front master cylinder / reservoir has blasted up nicely :P
went a little bit timid on this, best safe than sorry :??
The only minor problem is behind the window.
You can see a little corrosion, I've tried to get in throgh the slot at the rear but it's to no avail :(
Is it possible to remove the inspection window and then replace it :?: :?:
freddyz1r
PUM 329
freddyz1r
#135 PostAuthor: freddyz1r » Sat Mar 21, 2015 11:33 am
Made a start at stripping the front end.
Noticed straight away that the discs are held on by 6mm (allen head) studs, whereas the rear was held on by 5mm :??
6mm seemed to ring true with me, from some vague memory of snapping 6mm allen keys on I think GT750 discs :shock:
you'll notice on the second picture, the mudguard has a split in it :cry:
I did no this was their. But I had never seen this happen before :?:
it doesn't really matter because it won't be going back on :wink:
freddyz1r
PUM 329
