broken cylinder head!!!!! update!
bart
#16 PostAuthor: bart » Thu Aug 27, 2009 4:14 pm
Got my broken head back today,heres a few photos of it back from the welders
and heres a few more of it finished,a few hours in the garage with the die grinder ,
so nearly ready to put it back on. :D
tlc
#17 PostAuthor: tlc » Thu Aug 27, 2009 4:52 pm
That looks very tidy. I think you will have given a sigh of relief !
It`s also a good lesson in doing things low to the ground :??
bart
#18 PostAuthor: bart » Thu Aug 27, 2009 5:02 pm
I have got rid of the workbench,the garage floor is far better to work on!!! :idea:
I've just got to put a bit of metal filler in one or two places that didn't have quite enough weld ,then a good clean and resprayed,once it's back on the bike i don't think it will look too bad.
mick znone
#19 PostAuthor: mick znone » Thu Aug 27, 2009 5:46 pm
well done Bart, proper job, it makes sense :smile
bigmac103
#20 PostAuthor: bigmac103 » Thu Aug 27, 2009 6:32 pm
That looks a good job, well done! Also a lesson as TLC says, I recently took my engine out and after reading this I put a tyre underneath just incase.
Lost in the desert somewhere
#21 PostAuthor: Ginger Bear » Thu Aug 27, 2009 7:51 pm
Looks like a good job Bart. Bet you're glad you've done the right thing :up
Phil50
#22 PostAuthor: Phil50 » Thu Aug 27, 2009 10:51 pm
I have a Z900 cylinder head spare. It is in excellent condition around the park plug holes no cracks. It has only one fault and thats a piece of fin missing on cylinder 2 so a longer bit of studding is needed. Not really noticible except with close inspection.
regards
Phil
Garn 1
#23 PostAuthor: Garn 1 » Fri Aug 28, 2009 10:02 am
Wow! Bart, I'm impressed with that welding job. Good luck with the assembly.
RegardZ.
gbh
#24 PostAuthor: gbh » Fri Aug 28, 2009 11:32 am
Always best to do it right rather than take the easy way out. You can now bask in the glow of a job well done.
