Project 2010. Z1000A1. 2011,2012,2013 and now 2014
KWACKERZ1
#16 PostAuthor: KWACKERZ1 » Sun Nov 03, 2013 10:16 am
Having sold my other zed I have decided to turn this one into a classic racer for Spa and the Classic rackdays next year.
So I have ditched the dymags and fitted some 17" spokes and an old Harris I had lying around
(courtesy of MCZ900).
So the spec has changed slightly it will have
38mm Z1000r front end with Maxton conversions,
AP brakes
ZRX Rearshocks,
Dresda swing arm.
Rearsets
Harris clipon's
Harris will be blasted cut and repositioned (Or replaced if I can source a better one)
I am just dry building it to make sure everything aligns before stripping for paint etc, and to repair the output shaft in the motor.
(Thanks z1parr for the spare)
Hence it looks a bit scrappy at the moment with mismatched bodywork etc
The only issue is that it is sitting a bit lower on the 17"s and I need the ground clearance for Spa, So I would like to go to 18" rims,
(I have some lined up just awaiting them to be shipped :wink: )
I will probably sell on the 17 Akronts currently fitted once I get the new 18" ones built.
Could also do with a z1100r replica plastic mudguard if anyone knows of one anywhere.
One of these years this chassis may even see the light of day!!
KWACKERZ1
Progress.
#17 PostAuthor: KWACKERZ1 » Wed Jan 29, 2014 2:02 pm
Well things have moved on and I have managed to get further work done on this and the plan has changed yet again.
I have decided to park the DYMAGS and XJR swing arm for a future project and have acquired other bits for this one.
The objective changed to build another classic track day bike similar to my rescued from a friend project, but basically pepped up, but this is coming on so nice it will probably be a racer for the road.
So now we have:all the black bits powder coated.
I am fitting rearsets and have finished the frame mods to mount the rear master cylinder.
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/bikestuff003_zps4f4d2f01.jpg[/img]
A different front end from my friends Moriwaki bike its a z1000r maxton cartridge forks with Harris clip-ons and ap lockheeds calipers.
I have had to mate these to the new wheel of choice which is an 18 akront front rim and standard discs.
[/img]
In the rear I have fitted another akront 18" matched to another dresda and modified the brake mounting, and fitted Classicattack conti's.
So this is pretty much it at present.
Next jobs are strip the engine to replace the final drive shaft and put in a kickstarter.
Also should send my seat for recovering this week and then need to decide on the paintwork, I think I will go for an other black silver job as the previous one was so good. It will also match the rest of the bike nicely.
hillbilly
#18 PostAuthor: hillbilly » Wed Jan 29, 2014 2:14 pm
I wanted to buy that harris back off ian, :?? hope it sounds good on yours.
KWACKERZ1
#19 PostAuthor: KWACKERZ1 » Wed Jan 29, 2014 3:27 pm
I'll let you know, just had it blasted and have cut and adjusted the angle to fit better, just hope it will pass noise testing with the shortened can.
hillbilly
#20 PostAuthor: hillbilly » Wed Jan 29, 2014 3:58 pm
I was in the process of sorting it out,then swapped it,i cut four inch off it with a junior hacksaw,took ages,and wasn't straight.did sound good though.
neilbarrett
#21 PostAuthor: neilbarrett » Wed Jan 29, 2014 4:10 pm
ive a spare can if you get stuck,every time I drop a paragraph i expect to read CHANGE OF PLANS AGAIN :lol:
KWACKERZ1
#22 PostAuthor: KWACKERZ1 » Wed Jan 29, 2014 4:37 pm
Neil,
is'nt that the nature of project's :oops:
Thanks for the offer of the can, might take you up on that at a later date
#23 PostAuthor: Al » Wed Jan 29, 2014 9:46 pm
Phil someone sent me this i hope you find it inspirational.
Is Vic There
#24 PostAuthor: Is Vic There » Wed Jan 29, 2014 11:09 pm
Are you selling the dymags?
KWACKERZ1
#25 PostAuthor: KWACKERZ1 » Thu Jan 30, 2014 11:08 am
Could be tempted!!!
Might even have some other stuff for your Harris project drop me your email.
Is Vic There
#26 PostAuthor: Is Vic There » Thu Jan 30, 2014 11:12 am
KWACKERZ1 wrote:Could be tempted!!!
Oh will do :D
KWACKERZ1
#27 PostAuthor: KWACKERZ1 » Thu Jan 30, 2014 11:25 am
Have pm'd you
KWACKERZ1
Update
#28 PostAuthor: KWACKERZ1 » Wed Feb 19, 2014 2:37 pm
Quick update I have been working on the engine to replace the gearbox sprocket and whilst stripping it it all looks good.
Stripped the gearbox out and am Just awaiting the new shaft to arrive, so I thought I would look at fitting some bigger cams.
Bottom end is all sound, top end has APE adjustable cam wheels in it, Under bucket shims and relieved head and cam cover. Which all ties in with the receipts I got with the bike and the guy I bought it from said he ran stage 3 cams initially before replacing them with standard ones. ( that to be honest look brand new.) But it would be nice to have some cams to complement the porting and bigger carbs.
So I raided the stash and found some undetermined cams that appear to be about 0.5mm lift bigger than standards.
But then today I unearthed these little fella's
They are have casting letters in there saying CWC K269 7H27 USA But further investigation with my (old person monocle and trusty workshop companion), magnifying glass showed that part of the casting had been smoothed down and engraved with
RC400 127 87K
I can only assume from this that they are RUSS COLLINS 400 lift cams.
:up :clap :bng :hoo
Unless anyone knows better!!!
So just need to get them in check valve to piston and valve overlap.
:twisted:
KWACKERZ1
#29 PostAuthor: KWACKERZ1 » Wed Feb 19, 2014 4:34 pm
just found this.
neilbarrett
#30 PostAuthor: neilbarrett » Wed Feb 19, 2014 8:37 pm
you be best finding out at what rpm the bike will tickover before fitting em
