Zeded's quest for perfection
ZedEd
#16 PostAuthor: ZedEd » Wed Feb 03, 2010 8:55 pm
The bore has been increased to suite the twin caliper set up.
It may be something I'll go back to but I'm aiming to get the bike as close to factory as I can can
cheers for the input guys
Nosher903
#17 PostAuthor: Nosher903 » Wed Feb 03, 2010 9:47 pm
ZedEd wrote:The bore has been increased to suite the twin caliper set up.
Ah but according to Dave Marsden it was a Kawasaki optional extra at the time albeit hideously expensive. I'd say you wouldn't be compromising originality if you found the right splitter....
And...
You'll thank me if you ever have to ride it down Hardnott Pass! :D :D
Z1b, GPZ900r, XJR1300
ZedEd
#18 PostAuthor: ZedEd » Thu Feb 04, 2010 9:24 am
Haha
Yes, no doubt your right.
I would probably have kept the twin disc but the one fitted has been modified slightly and uses spacers for some reason, and as it wasnt fitted to the bike from new I'm removing it for now.
wilsonsjw11
#19 PostAuthor: wilsonsjw11 » Thu Feb 04, 2010 10:00 am
The spacers are usually fitted to make the left hand caliper bracket into a right hand unit as the mountings orientation is different.Right hand brackets are available from Zpower/Z1Enterprises but they are pattern.
Regards
Steve
ZedEd
#20 PostAuthor: ZedEd » Sat Dec 24, 2011 1:00 pm
Its been a while but theres been a lot of progress and the bike is now finished......for now
To cut a long story short I did what I could but progress was slow. I was then introduced to a guy called Paul who took the bike on and brought it up t the standard its in now
I won't go into all the finer details but some fantastic work has been carried out and many many parts have been changed for the correct items. Parts such as the headlamp, various bolts etc. Theres still a little way to go but we are getting down to the small details to get it very close to perfect.
I'll be looking out for early model forks in the new year and will have quite a few parts for sale too.
Some pictures that tell a thousand man hours
As it was before it went away
MMM, Houston - we have some problems
And here she is, ready for next year. Still more to do yet but some of the hardest work is now done
Thats it for now, its all tucked up and secure for the winter. I'll be looking for some parts and will have a few bits for sale in the next few weeks too.
pertonpc
#21 PostAuthor: pertonpc » Sat Dec 24, 2011 4:53 pm
Well Done ED
Looks like a right minter now mate. Will be interested to see what you are still short of - can't be much by the look of things.
Does she get to spend the winter in the conservatory??
Paint job looks fab - original or who did it??
Happy Xmas from Mark
ZedEd
#22 PostAuthor: ZedEd » Sun Dec 25, 2011 2:40 pm
Hi
Not sure on the paintwork but its very very good
Steve Cooke
#23 PostAuthor: Steve Cooke » Sun Dec 25, 2011 3:05 pm
Lovely looking bike,
with regards to the optional twin disc setup, I think the Kawasaki supplied option was at least initially a different caliper as in a H2 type or something.
PJ
#24 PostAuthor: PJ » Sun Dec 25, 2011 3:07 pm
That really does look fantastic - well done on the refurb,
I assume you after a tacho?
ZedEd
#25 PostAuthor: ZedEd » Sun Dec 25, 2011 3:22 pm
Hadn't thought anything of the Tacho, whats the difference?
PJ
#26 PostAuthor: PJ » Sun Dec 25, 2011 3:53 pm
ZedEd wrote:Thanks
If you look at your speedo tthe gap between the ND and the MPH is correct the rev counter has a smaller gap - I hope that makes sense
Z1RII
#27 PostAuthor: Z1RII » Sun Dec 25, 2011 6:45 pm
tacho is the later Z900 up style.
72 z1 has the straight 7 too not the rounded one.
the line between 0 and 1K rpm should be in the middle not near to the 0
deluxe bike
:shock:
regards
amir
ZedEd
#28 PostAuthor: ZedEd » Wed Dec 28, 2011 11:31 am
Thanks guys, I''ll have a careful look into it
72 Z1 900
#29 PostAuthor: 72 Z1 900 » Fri Dec 30, 2011 5:54 pm
What a great refurbishment Ed! Is she an early 72 Zed or after the first 2200?
Cheers!
Steve
irhobotolo
#30 PostAuthor: irhobotolo » Fri Dec 30, 2011 7:02 pm
ZedEd wrote:To cut a long story short I did what I could but progress was slow. I was then introduced to a guy called Paul who took the bike on and brought it up t the standard its in now
Would that be Paul Scanlon ?
