Clutch
CAT3
#16 PostAuthor: CAT3 » Fri Jun 24, 2011 8:11 pm
The clutch on my 955i sounds like it's similar in design.
On the Triumph it's possible to fit the clutch cover with the operating arm in the wrong position. It looks correct, but when you operate the clutch lever it doesn't disengage the clutch.
Sounds very similar to your problem so might be worth a second look ?
mikey
#17 PostAuthor: mikey » Fri Jun 24, 2011 9:51 pm
Crofty wrote:So bearings on output shaft replaced, do they spin OK? Clutch might be fine and its the shafts in the g/box causing a problem?? Just a thought
Looked at that crofty, shaft drive rotates ok, took swing arm off took the shaft drive shaft out bearing turns smoothly no snatching or anything.
mikey
#18 PostAuthor: mikey » Fri Jun 24, 2011 9:52 pm
CAT3 wrote:The clutch on my 955i sounds like it's similar in design.
Ok definetly wprth a look tried everything else
mikey
#19 PostAuthor: mikey » Sat Jun 25, 2011 1:03 pm
OK stripped the clutch out again today and rebuilt it again to the suzuki
workshop manual 4th time exactly the same everytime
but for some reason its working now still got a bit of clutch drag but hoping that may clear with use.
Crofty
#20 PostAuthor: Crofty » Sat Jun 25, 2011 4:08 pm
Good Mikey, glad its decided to start working (a bit), last thoughts are wonder if the basket dried out, no oil to let plates slide plus a bit of wear on the fingers making the whole lot jam up. If so it should loosen up a bit with use, but really baffling. Tried to find an emoticon with a head scratch, but can't.
mikey
#21 PostAuthor: mikey » Sat Jun 25, 2011 8:01 pm
Not going to question it jim just glad its working
as i say with bit use it may start improving
Crofty
#22 PostAuthor: Crofty » Sat Jun 25, 2011 8:47 pm
Was just reading an article and it mentioned clutches sticking with certain types of oil, was that changed Mikey?
#23 PostAuthor: Pigford » Sat Jun 25, 2011 9:18 pm
There a minor modification thats done on the 1100 baskets that allows much smoother gear changes, etc....... Its on "oldskoolperformance" site somewhere, to name but one - maybe worth checking out :?:
mikey
#24 PostAuthor: mikey » Sat Jun 25, 2011 11:17 pm
Crofty wrote:Was just reading an article and it mentioned clutches sticking with certain types of oil, was that changed Mikey?
It was obviously changed during the engine re build but not in this episode with the clutch strange one though never ever had this grief with a clutch
