A work in progress
z1bnackerkwacker
#16 PostAuthor: z1bnackerkwacker » Sun May 13, 2007 1:47 pm
a little work for lttle money.
Last edited by z1bnackerkwacker on Fri Jun 15, 2007 3:50 pm, edited 4 times in total.
ninjajen900
#17 PostAuthor: ninjajen900 » Sun Jun 10, 2007 11:45 pm
nice zed,well worth the money!pipes look in good condition,would(should) make a fortune on ebay
ade woollams
#18 PostAuthor: ade woollams » Mon Jun 11, 2007 8:30 pm
i think your ideas are along that of most z9 owners back in the 70's of a custom look.just like the z1000a1 one i had which had the devil 4-1 F1 track pipe on it :D i can send a pic if you email me on adrianwoollams@btinternet.com
i wish i still had that bike i changed the devil for a piper which was a nice shape pipe..
z1bnackerkwacker
#19 PostAuthor: z1bnackerkwacker » Thu Jun 14, 2007 10:31 pm
ninjajen900 wrote:nice zed,well worth the money!pipes look in good condition,would(should) make a fortune on ebay
Hi, Hate the pipes, will be going as soon as make my mind up and something comes along at right price....
As for Ebay,,,,Who knows?....It's not for sale...... :D
bunnysZ
Granny Magnet
#20 PostAuthor: bunnysZ » Thu Jun 14, 2007 11:23 pm
what did you use and how did you clean those carbs, I have a set in the gge , that are powder coated , and want to get it off.
was yours black paint
z1bnackerkwacker
#21 PostAuthor: z1bnackerkwacker » Thu Jun 14, 2007 11:36 pm
Not sure what the paint was some sort of heat res'/enamel ?, was a bitch to get off. Used Nitromors and hours of gentle scraping with Stanley blades/mini sculture chisels, Polished with Dremil, Washed, dried in oven (not too hot), I flush out all insides using a syringe (used for filling printer cartridges), filled with petrol from a bowl and pump it through all airways (millions of times) so you know they are clear. Or WD 40
Full kits from Z enterprises.....Cheap job now runs perfect...
Or if you're not tight like me you can cough up loads of dosh and get someone like Smethurst' to do them. :lol:
ANZed
#22 PostAuthor: ANZed » Tue Jun 26, 2007 12:28 pm
Can you tell me if the 4 x 2 pipes shown on your bike are for sale yet as I am re-building a Z1000 at the moment and looking for a set
z1bnackerkwacker
#23 PostAuthor: z1bnackerkwacker » Tue Jun 26, 2007 4:20 pm
sent you p.m..
z1bnackerkwacker
#24 PostAuthor: z1bnackerkwacker » Mon May 26, 2008 5:18 pm
Year 1 EFF ALL, Carbs knackered parked it up, hence "Knackerkwacker"..
Year 2 sorted carbs m'o't'd and just rode it....Not a lot..............
Year 3 nearly finished my shed and have started some work on zed, just going through bike at present to see what's shagged and what's o'k :roll:
Checked shims and ordered, plus: Pingel, Ape tensioner, Clymer so I can burn my Haynes..... and awaiting, :save
Today i've stripped both my front calipers, inspected, cleaned put back, together (temporary) o rings perished, don't have any, one pin seized in each caliper, don't know if any newbie's would like to see photo's?
of anything I do.......
Master cylinder leaking, now removed and have 5/8 kit ready to fit,
Fiddly little bar steward and can't find my little circlip pliers, moving on..
Next bit is where you lot come in :fou ........
DON'T ALL SHOUT AT ONCE .........
Rear mudguard/light sits very low, you can see the mark on lense so obviously hasn't always been this way, mudguard is a shorty but don't think it's Z1 SERIES, very similar, (what is it?), bolt holes line up, What about light bracket?, See pic's.....Idea's/answer pleeeze........
May go for strip down this winter to paint frame, depends how much the misses pisses me off, if a lot, i'll be in shed, Hated the gold frame at first but it's starting to grow on me, it's either gonna be that or Gunmetal silver metallic or ?????? :roll: ....Definately won't be black :o .
Any way back to business......
#25 PostAuthor: Pigford » Mon May 26, 2008 6:09 pm
Looks like a Kawasaki type rear muddy to me..... :|
z1bnackerkwacker
#26 PostAuthor: z1bnackerkwacker » Mon May 26, 2008 6:13 pm
Pigford wrote:Looks like a Kawasaki type rear muddy to me..... :|
Possibly, but the question is.......
Why does it sit like that ?????? :roll:
#27 PostAuthor: Pigford » Mon May 26, 2008 6:15 pm
Its off a custom/ltd jobby I think.... but don't quote me on it :??
Good to hear you're off and running with it (at last :roll: )
z1bnackerkwacker
#28 PostAuthor: z1bnackerkwacker » Mon May 26, 2008 6:23 pm
Pigford wrote:Its off a custom/ltd jobby I think.... but don't quote me on it :??
Prepare for a bigger shock :shock: :shock: , in middle of returning your Rd to standard as well, you can see wheel and spare frame in pic' if you look...
z1bnackerkwacker
#29 PostAuthor: z1bnackerkwacker » Thu May 29, 2008 6:33 pm
Ok, as usual i'm not payin' attention assumed my master cylinder was 5'8 as it's taller, than single....
ANYONE CONFIRM, IS IT RIGHT?. WHAT MODEL THIS WAS FITTED TO ?
z1bnackerkwacker
#30 PostAuthor: z1bnackerkwacker » Fri May 30, 2008 3:43 pm
I'LL ANSWER MY OWN QUESTION..........
Now had Master cylinder in bits, what a t**t to get out the circlip is, Had to buy a new circlip pliers and mutilate it with my Dremel so as to get in cylinder recess, Guts are identical to Z1b 5/8 & kit is now fitted and working :D ....
