Flat track style z
debben1
#16 PostAuthor: debben1 » Fri Oct 21, 2011 6:32 pm
Hello Coldsummer yes I dont want to cut this tailpeice about as they are quite rare now, so i have decided to stick with the original tail peice and move it forward 80mm and fabricate a matching seat base.
Gus
#17 PostAuthor: Gus » Sat Oct 22, 2011 9:48 am
Hi Steve
UNATEC Make the Z butts.
and this guy is selling them on ebay with or without pads (I'm assuming they are connected to Unatec)
http://www.ebay.co.uk/itm/KAWASAKI-Z900 ... 519779d9cc
and this guy has one at £45
http://www.ebay.co.uk/itm/zbutt-streetf ... 4aaf1ade56
If you like that sort of thing :lol:
I think moving the original forward is the way to go personally.
"Set the GRINDER on it"
debben1
#18 PostAuthor: debben1 » Sat Oct 22, 2011 5:44 pm
Thank you Gus, I didnt know they where still available, think I will stick with the original now, have started working on a replacement seat base
debben1
#19 PostAuthor: debben1 » Thu Nov 03, 2011 4:49 pm
Little bit of progress this week, decided to tackle the seat base now I am happy with the tail peice location. Want somthing smaller than the standard large seat as no pillions required but want something less makeshift than the foam covered race seat unit.
sanderz
#20 PostAuthor: sanderz » Thu Nov 03, 2011 7:35 pm
Very neatly done that seat base, like it.
Wots up DOHC
coldsummer
#21 PostAuthor: coldsummer » Thu Nov 03, 2011 8:15 pm
debben1 wrote:Hello Coldsummer yes I dont want to cut this tailpeice about as they are quite rare now, so i have decided to stick with the original tail peice and move it forward 80mm and fabricate a matching seat base.
Steve, that's similar to my number seven project. Great minds.......... :wink:
#22 PostAuthor: Ginger Bear » Thu Nov 03, 2011 11:40 pm
Simon, I'll sort those forks sorted out asap, I promise. :oops:
Steve, I've not intentionally hi-jacked your thread...... :oops: :oops: :oops: :oops: :oops: Seat base looks good. :up
debben1
#23 PostAuthor: debben1 » Tue Nov 22, 2011 9:00 pm
Rearsets nearly finished and started on the handle bar set up, going to have clip on style bars but still be high and wide
Have ordered some countersunk 10mm stainless screws so the footrest plates are flush, brake pedal side is also nearly finished
Next job is to fit the battery box
#24 PostAuthor: Pigford » Tue Nov 22, 2011 9:21 pm
Hmmmm, interesting paintwork :| ,,, and a hanger attached to the headstock :P
#25 PostAuthor: ADRIAN H » Wed Nov 23, 2011 8:33 pm
Looking good in the flesh.
debben1
#26 PostAuthor: debben1 » Fri Dec 09, 2011 11:08 pm
Battery box is made and fitted, now i can start locating the electrics and components
debben1
#27 PostAuthor: debben1 » Fri Dec 09, 2011 11:22 pm
Started on engine build too, First job was to strip and check the crankshaft, then polish all the parts before re assembly
#28 PostAuthor: Pigford » Sat Dec 10, 2011 8:13 am
So whats the spec for the motor then Steve :?: Whats carbs - or FI :?:
debben1
#29 PostAuthor: debben1 » Sat Dec 10, 2011 2:15 pm
1170 with Mikuni RFS38 :)
spondonges
#30 PostAuthor: spondonges » Sat Dec 10, 2011 2:27 pm
debben1 wrote:Started on engine build too, First job was to strip and check the crankshaft, then polish all the parts before re assembly
How the heck would you balance all that together???? :shock: :shock: :shock:
I'd rather be riding my Z1 thinking about God than sitting in a church thinking about my Z1..
