Marve's BiTsA Z1000j3
marve114
#16 PostAuthor: marve114 » Sun Dec 04, 2011 3:40 pm
Well, It was nice to meet guyzed and garyd at kempton nice to put faces's to the names so to speak !
Any way got my bandit wheel " Thanks gary " and it goes in with room to spare NICE and most importantly it looks PHAAT !! lol just gotta have a look at the wheel aligment
Got stuck into the wiringing as well pulling my f..king hair out arrrrhhhhhhhh , that little moan aside i sourced the problem and now the motor turns over *started to dance like a school boy * on the button no vrrrrmmmmm vrmmmmm yet didnt get that far as it started raining lol
marve114
#17 PostAuthor: marve114 » Tue Dec 06, 2011 5:07 pm
Had a job cancel today so it gave me a chance to get out in the garden in the day light and get some work done .........
First up i had a quick look at the wheel aligment with my rather crude poles :lol: dont look to sad and i had it pretty much there within 1mm-2mm
( Pics are SH1TE but you get my gist )
Then i thought what the hell, Lets get her running finished off the basic electrics ( just lights, Bandit ignition and clocks left ) Pulled the plugs * SPARKING * :twisted:
So with that i filled the carbs with petrol and gave it a few turns nearly gave up, But she went vrmmmmmmm pop pop vrmmmmm .
A little rough but she runs carbs well need a basic set up
Looks a little lean to me ????
Also going to not use the standard foot plates and use these bad boys
marve114
#18 PostAuthor: marve114 » Tue Dec 06, 2011 8:07 pm
Guys just so i dont flood up the bike help section
im running 36mm mikuni flatslide's with a gpz1100 engine and bitza of an exhaust
Just because it was a bit of a mare to start and was reluctant to rev up if you bliped the throttle and was poping and coughing about and didnt really want to idle but it was fireing on all 4 pots .. But it hadent run for nearly a year !
Now bearing in mind ive never checked these carbs or there settings
What would be a good sort of setup to start with on the carbs ie ......
main jets
slow running jets
mixture screw setting
and needle position
Many thanks guys :)
#19 PostAuthor: Pigford » Tue Dec 06, 2011 8:19 pm
My 1075 Z1000A2 runs RS36's + K&N's + 4:1...
130 mains
17.5 pilots
1 1/4 fuel mix screw
Needle - clip on 2nd down
:P
marve114
#20 PostAuthor: marve114 » Tue Dec 06, 2011 8:28 pm
Nice one pigford il have a look at mine when i get a chance so much more to do but at least it's on this thread and it will save me asking later :lol:
marve114
#21 PostAuthor: marve114 » Fri Dec 16, 2011 5:05 pm
My other half gave me a camera to take some pics of my bike for you guys aint she sweet ! :P
Been busy tackleing the wiring mess i let my self in for bandit clocks and ignition all wired up And working might i ad havent tested the rev counter as im checking the carb seting over !
Headlight on and working
Battery box sort of finished
Rear wheel put in needs final alignment but its almost there
Also had a look at the rearsets only problem is the rear brake master cyclinder is going to be laying right under my side panel ???
I got the bottom hole lined up with original mount and drilled the other hole straight through the original foot rest hanger ( AS A TEMP FIX)
Slowly coming together im Planning on getting this as far done as i can so can cruise around summer time on it , I wont hold me breath !
nanno
#22 PostAuthor: nanno » Fri Dec 16, 2011 5:20 pm
Looking excellent!
Padders
#23 PostAuthor: Padders » Fri Dec 16, 2011 7:01 pm
Keep at it
#24 PostAuthor: Ginger Bear » Fri Dec 16, 2011 8:44 pm
Good stuff Lee.
Looking at that rear master cylinder mount, it probably won't be in the right position/angle once the brake pedal is in the right place.
Shouldn't be too hard to make another mount from some ally bar/plate (5mm?) that will mount the rear master in a more upright position, using the original rearset mounts.
#25 PostAuthor: Rich » Sat Dec 17, 2011 7:14 am
looks like the Harris has a street baffle in it - probable won't help the carbs.
marve114
#26 PostAuthor: marve114 » Sat Dec 17, 2011 10:04 am
GB I was thinking about using some 10mm alloy and standing the mastercyclinde upright and bringing the pegs futher forward , to bring my knee's up and feet forward !
And im going to have the street baffle out well spotted rich ! Cut the baffle out and replace with some perferated tube and of course exhaust wadding !
marve114
#27 PostAuthor: marve114 » Sat Jun 16, 2012 2:26 pm
Not much to report sadley but i had her out today and done a little bit , Then i t started to rain so that stoped play
garyd
#28 PostAuthor: garyd » Sat Jun 16, 2012 8:35 pm
Hi...funny how these things take muuuuch longer that we plan.
Must admit, work and the cold has kept me out of the garage reacently. :cry:
mutz-nutz
#29 PostAuthor: mutz-nutz » Sun Jun 17, 2012 9:26 am
:D keep up the good work and supply of pics its going to be a mint when done m8 :D
turn full circle and bite ya own arse !!
marve114
#30 PostAuthor: marve114 » Thu Jun 06, 2013 8:39 pm
Not been up to much been busy working at my new job.
But did find out the land lord is a bit handy with a milling machine and he kindly jazzed up my old foot rest plates .
They are pretty raw at the moment having been shot blasted
