zmans cosmetic rebuild.FFFFFFFFFFFFFFFFFFFinished
- paul doran
I thought id give you a bit off an up date so you dont think ive give up
Im in the process of sorting engine out.All relevant helicoiling has been done on cam cover and spark plug thread sorted out.I have also been decreasing the engine cleaning ready for painting.What a messy and time consuming task
Head is now decoked.
There was also some broken finns on the head.I plan to fix these and paint engine this week.
Will post pics when i get to that stag.
keep thoses wheels turning
So things are moving along
Bottom end off engine now painted.haven't done top yet as gas torch hasn't arrived.so haven't repaired finns
been polishing engine covers[dont envy mikeys job]very dirty
But also satisfying to
and ive temporary put them on engine as hopefully with a bit of help from steve T i will be putting the bottom end back in the frame tomorrow
Then i will take them off for i final polish before fitting with new gaskets
this is a before.and then a few after pic
They do look so shiny now after putting my mucky paws all over them
if all goes well should be posting in frame pics tomorrow
- paul doran
Re: yep
coldsummer wrote:zman wrote:my bit for the environment![]()
Well just make sure you don't leave it parked outside on recycling day
Well the engine in the frame
I really like the contrast between the frame and engine
Even if i say so my self.
I'm sure when doing these projects we pick up tips that would be useful to others[may be a new section on the forum]
this may help any one painting their engine.if like me you finned masking up a real pain
Then simply paint engine with all covers still fitted .Then remove covers when paint is dry.As high temp paint does not get hard till its been through a heat cycle.All you have to do is remove paint with white sprite.simple
That's it till after xmas.I WISH YOU ALL A MERRY XMAS and hope to meet more of you in 2012
Hi pigford
I used wurth satin high temp.It was recommended to me buy another member.Ive used lots of wurth products and they have always be good.
WORD OFF CORSTION.
The paint is very easy to scratch or remove with wight spirit until been throw
a heat cycle.So take care
WORD OFF CORSTION.
- Ginger Bear
Hi Zman have you had success with the Mapp gas and managed to weld fins yourself ?,asking cos i had a go with little success, including getting the head up to correct temp in our double oven and filling house with smoke
PAULJAC47 wrote:Hi Zman have you had success with the Mapp gas and managed to weld fins yourself ?,asking cos i had a go with little success, including getting the head up to correct temp in our double oven and filling house with smoke
What sort of oven did you use... Electric or Gas
So what sort of filler rod is used with the Mapp gas - assuming you can get it hot enuff
Hi Paul
No luck
i brought the torch and mapp gas as that Durafix recommended to me.But same as you.Will not get hot enough.
I rang them and they did offer money back.But brought torch else where
No luck
- Ginger Bear
Happy new year to all.
So lets update you all with whats been going on.
I have done a final polish to the ally engine cover and fitted them with new gaskets.
refurbished starter clutch as it used to make a bit of racket.
Swing arm,triple trees and a few other things are at the cromer's.
I have stated on refurbishing the battery box area.
below are a before and a few after pictures.
Hope you can tell which is which
chrome parts due back on the 20th.So should really get things moving then.
