Weaver's ELR
london calling
#16 PostAuthor: london calling » Fri Jan 27, 2012 8:50 pm
Check the oil level,ideally you want to be close to the min level on the sight glass but obviously above it :wink:
Might be worth removing the sump and oil pump for a good clean while you're doing the top end.
Jack
weaver
#17 PostAuthor: weaver » Fri Jan 27, 2012 9:06 pm
gonna check the two inner plugs when I get chance and compression test it as well,could it just be worn valve stem oil seals?
Is Vic There
#18 PostAuthor: Is Vic There » Fri Jan 27, 2012 9:55 pm
Looks good, wish I could go and pick mine up :twisted:
Still waiting for the bloody thing to leave Blighty :roll:
weaver
#19 PostAuthor: weaver » Mon Jan 30, 2012 4:51 pm
after doing some thinking and having another look at the bike,I realised that what I thought was a decibel killer of some description in the end can had no means for the exhaust gases to escape,what its purpose is I have no idea,so obviously the engine has been unable to breathe.I removed the offending item and after charging the shagged battery took it for another run.Well it pulls so much stronger now which isnt really surprising!
After a good run took it home and pulled the engine breather,no smoke just a bit of steam,checked the two outer plugs and they are now the right colour.
So I have been shopping again,new battery,iridium plugs,new air filter ordered and picked up an oil filter and some oil.New seat cover arrived as well.Still need to compression check and may order some dyna coils,I want the bike running properly before I strip it for cosmetics.
Been in touch with a company about ceramic coating the harris exhaust,they reckon about 120 to coat the downpipes
http://www.camcoat.u-net.com/index.htm
#20 PostAuthor: Ginger Bear » Mon Jan 30, 2012 6:33 pm
Camcoat did these for me. I can highly recommend them. :up
weaver
#21 PostAuthor: weaver » Mon Jan 30, 2012 6:49 pm
nice 1 will give them a shout when i am ready
weaver
#22 PostAuthor: weaver » Sun Feb 05, 2012 8:41 pm
zrx fairing and screen on their way,as are dyna coils and taylor leads,is there an ignition advancer for this model?
weaver
#23 PostAuthor: weaver » Sat Feb 11, 2012 8:22 pm
the bike was a bit reluctant to start,but with a new battery and hooked upto a trickle charger it is starting 1st time.
Air filter and crankcase breather fitted to help the motor breathe properly.
The harris pipe that came with the bike had a big dent in one of the down pipes so got some rubber bungs off ebay,filled it with water and lobbed it in the freezer for a few hours.This got 95 % of the dent out so took it to a local fab shop who put a blob of weld on the remains of the dent and I ground and filed it smooth,worked out really well.Got a race baffle for it and some new badges as well.
weaver
#24 PostAuthor: weaver » Thu Jul 05, 2012 6:57 pm
things are slowly progressing,forks and yokes swapped for kais overhauled zrx12 items,modded kerker,still got new chain and sprockets and zxr750 wheel to go in,seat refurbished,won a brand new clock cover on ebay,finally got taylor leads,after waiting 3 months from a uk supplier bought them direct from the states,dyna coils still to go on,once everything is sorted it will get stripped for frame repainting and engine cosmetics,be autumn time probably
mutz-nutz
#25 PostAuthor: mutz-nutz » Fri Jul 06, 2012 8:49 am
:D its going to be worth all your effort keep it going m8 :D
turn full circle and bite ya own arse !!
weaver
#26 PostAuthor: weaver » Fri Nov 09, 2012 2:41 pm
frame,swingarm and other bits back from painting,shock springs have been power coated and the rest painted
needaz1100r
#27 PostAuthor: needaz1100r » Fri Nov 09, 2012 5:00 pm
You're a bit ahead of me there Weaver, looking good.
You've made me wonder if my Zephyre stuff is modern enough, that ZRX front end looks the business.
Cheers,
Mark
weaver
#28 PostAuthor: weaver » Fri Nov 09, 2012 5:28 pm
the zrx running gear works well mate,front end goes straight in as well,swingarm just needs an insert to make up for the difference in the shaft diameters
jules
#29 PostAuthor: jules » Sat Nov 10, 2012 10:06 pm
Best pull my finger out aswell and get on with mine!!!
P.U.M
'78 z1000a2,'83 1000r,'76 Z900a4,07 gsxr1000k6,'01 bj250,'03 husky 450,'83 Z1170r Lawson.
kawaman21
#30 PostAuthor: kawaman21 » Sat Nov 10, 2012 11:58 pm
is that one of them polish zrx fairing from ebay,whats the quality like.........
